Overheating problems....
Old Jun 17, 2003 | 06:22 PM
ek9si's Avatar
Default Overheating problems....
MY gsr keeps overheating when I drive with the a/c on, then I have to change the thermostat. Then with the a/c kept off with a new thermostat, car is fine. Ive changed it three times already. I've taken it to acura and they said I need a new cooling fan motor. Got that and it still does it???I'm going to change the thermostat one more time before I take it back to them. They also said the thermostat was closed before. How does it close? Does anyone know? Thanks.
Old Jun 17, 2003 | 11:51 PM
salbaje's Avatar
Default Re: Overheating problems.... (ek9si)
your thermostat might be sticking. did you bleed the coolant system?? Is your fan kicking in when its hot??
Old Jun 18, 2003 | 12:39 AM
poison's Avatar
The thermostat shouldn't much to do with the cooling system if it only over heats with your A/C on.
Sounds to me like your A/C fan and/or your primary cooling fan is not turning on.
Jump the connector and see if it turns on.
Old Jun 18, 2003 | 04:42 AM
ki3t's Avatar
This user can set his title.
What kind of radiator do you have? Maybe it's time to upgrade that.
viciousef9
Mar 5, 2008 05:28 PM
RTW DC2R
Apr 12, 2007 05:24 PM
91accordwagon
Jan 16, 2005 07:28 PM
hitop
Jan 16, 2003 03:38 PM
senpai
Dec 20, 2002 06:08 AM
