b swap header problems
Old Jun 17, 2003 | 05:51 PM
civickiller's Avatar
Default b swap header problems
ok im swapping in a ls motor and i got my oil pan on, but my ls header wont fit because its hitting the oil pan, just right around where the pipe bends on the lower piece, how did u other b series swap guy handle this ?
Old Jun 17, 2003 | 06:02 PM
RCautoworks's Avatar
Default Re: b swap header problems (civickiller)
Are you using an ls oil pan ? And your using an ls header right, then it should fit. If your using a b16 header then it would hit, but if your using an ls header on an ls, you should have no problems.
Old Jun 17, 2003 | 06:11 PM
Default Re: b swap header problems (90blackcrx)
yeah i know, thats what confuses me
the guy told me its an ls header
SIRX's Avatar
he said it was an ls oil pan and header. Sounds like you got a 16 header instead. Usually there's enough room for a 16 header to work on a 18. Are you having clearances issues at the cross-member?
Old Jun 17, 2003 | 06:13 PM
Default Re: b swap header problems (SIRX)
Did you take the header studs out of block when you were trying to put the header on ?
Old Jun 17, 2003 | 06:24 PM
i never took the header studs out, and i am having clearence problems at the oil pan, the cross member is fine.
Old Jun 17, 2003 | 06:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">i never took the header studs out, and i am having clearence problems at the oil pan, the cross member is fine.
Well when I installed my header on my car, I needed to take the header studs out because part of the header kept hitting the oil pan. Probably not your problem but I'm just telling you cause it might help you out. If that does not, then you got the wrong header on there.
Old Jun 17, 2003 | 07:03 PM
ok but why would taking out the header studs affect how the header is positioned, u mean the exhaust mani studs right, not anything on the header itself
Old Jun 17, 2003 | 07:18 PM
No nothing on the header, mine would not clear the oil pan with the studs in. It would not come high enough and forward enough with out the one piece that bolts to the engine by the cat.
Old Jun 17, 2003 | 08:50 PM
the thing is that, i switched oil pans, and the stock one that was on the motor when i got it, it was dented in right where my new oil pan is hitting, so the guy dented the oil pan to make it fit. the reason i had to switch oil pans is because the car flew down a hill and got the bottom dented enough where hte oil pick up itself was dented. so instaed of trying to take the dents out, i just bought a new one, but now hte header doesnt clear the new one
Old Jun 17, 2003 | 10:12 PM
You sure you got the right pan ? And the guy that owned the engine before you is a jackass.
Old Jun 17, 2003 | 10:34 PM
i tried to compare it as best i could and it seemed to be ok and it did bolt up to the ls and the guy i bought it form said its from an ls. but i mean it looked like the oil pan i took off
Old Jun 17, 2003 | 11:44 PM
Well then its not an ls header.
Old Jun 17, 2003 | 11:49 PM
**** just one more problem after another. ok its not an ls header, what kidn of header will bolt up to the ls but not be an ls header, from what engine ?
Old Jun 18, 2003 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">**** just one more problem after another. ok its not an ls header, what kidn of header will bolt up to the ls but not be an ls header, from what engine ?</TD></TR></TABLE>
Any b18 header will work. If you header bolts to the head, then you might just be able to get the down pipe from an ls or any b18.
Old Jun 18, 2003 | 11:33 AM
i know anyone selling the bottom half of the header, but **** the top half itself could be positioned wrong, im not to keen on how they make the headers
GenIIIMrDuece
Mar 21, 2008 08:17 AM
switchedg2
Jun 6, 2007 03:03 PM
numbnuts22715
Apr 10, 2007 08:23 PM
ekjay
Sep 9, 2006 04:40 PM
CivicHatchback14
Jan 31, 2004 06:41 PM
