Bogging out at WOT
my b16 runs great up to 99.9% throttle and then right when the pedal hits the floor at 100% throttle the engine bogs out and i have to left off the gas. if anyone has exprienced this, please help me.
Tp and Map sensor are both good i did a voltage test on them.
Also my VAFC reads 100% throttle at idle and vice versa for when throttle open counting down. I check and double checked wiring and its all correct nothing backwards. i even disconnected the VAFC and still had the problem with WOT bogging.
Im only throwing a code 41 (heat o2 sensor isn't hooked up thats why), code 20 for electronic load detector which the 90-93 tegs don't have, and the only important one is the code 14 for the IAC ( i need a new one, already tried cleaning out), but i didn't think that had anything to do with WOT.
Any guess's to what could be wrong??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Regular Series »</TD></TR><TR><TD CLASS="quote">Plugged cat?</TD></TR></TABLE>
i have a test pipe in, with a custom exhaust all the way back with no resonators. So i don't think it would be a clog.
Demonvw
Honda Civic (2006 - 2015)
Jul 1, 2018 09:30 AM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
