Did all 96-00 Civic EXs have 10.2 front brakes??????????????????
like the title says, did all 96-00 EXs have 10.2 front brakes?????????? the reason im asking is because i want 10.2 front brakes for my EK hatch and i already know that SI's came with 10.2 front brakes and the EX/SI should be the same, but what i dont know is if it came with them for all 96-00 Civic EX's.......
99-00SI front brakes = 96-00 EX front brakes??????? from the ulitimate brake thread it says its trrue but can anyone confirm this with absolute certainty???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx »</TD></TR><TR><TD CLASS="quote">99-00SI front brakes = 96-00 EX front brakes??????? from the ulitimate brake thread it says its trrue but can anyone confirm this with absolute certainty???</TD></TR></TABLE>
i can. ex front rotor/caliper/pad/line are exactly the same. i purchased a complete si brake swap for my 96 ex, and later realzied i did not need the fronts b/c they are identical. when you order aftermarket pads or rotors, you'll notice most will say '96-00 ex/si'. this of course does not apply to non-ex models.
thanks man! thats exactly what i wanted to hear....still got the SI front brakes??? im looking
Honda changed from the 9. whatever to the 10.2 in the early nineties eg. I think its somewhere between 93 and 94. All of the 96-00 front discs are the same whether it be civic or integra. I would only do the rears if you want to do a disc conversion. You have to get the 40/40 prop valve from an EK 99 si. I have an integra one that doesn't work right I would have to rebend all of the hardlines to make it fit.
Good Luck
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">Honda changed from the 9. whatever to the 10.2 in the early nineties eg. I think its somewhere between 93 and 94. All of the 96-00 front discs are the same whether it be civic or integra. I would only do the rears if you want to do a disc conversion. You have to get the 40/40 prop valve from an EK 99 si. I have an integra one that doesn't work right I would have to rebend all of the hardlines to make it fit.
Good Luck</TD></TR></TABLE>
They are not all the same. I have two 1997 Honda Civics sitting in my driveway so I ran out to check.
1997 Ex = 10.2
1997 Hx = 9.something
Check the altimate brake thread...it covers most of this information.
PauL
1997 Ex = 10.2
PauL
sk8shorty012
Jan 13, 2011 02:59 PM
anjapower
Aug 3, 2007 07:34 AM
