Just bought a JDM 23mm... What am I missing to put it on...
Ok, I know which parts I need to order... but I am not 100% sure which part is which... Oh, it's going on a 93 Civic CX
Here's what I got... GSR rear LCAS and this..
I know I'll need a mounting kit (I'll prolly go BSQ)...
Here's the list of what I need, but I want to know what exactly do I have already (in the pictures above)
1.) 52300-ST7-Z01 rear swaybar ($71.77) - I got this (actually I got the JDM 23mm one so not really)
2.) 52315-ST7-Z01 swaybar bushing ($4.49) (2 needed) - I'm guessing I have these?
3.) 52308-SS0-000 bushing bracket ($6.09) (2 needed) - Is this the D Bushing bracket? If so, I'll need these...
4.) 52316-ST7-Z00 endlink bushing ($1.76) (2 needed) - I'm also guessing I have this since the endlinks I have look complete...
5.) 52312-ST7-Z00 endlink bushing collar ($5.00) (4 needed) – Actually I only need 2, but either way, I already got these right?
6.) 90175-ST7-Z00 bolt (8x35) ($2.47) (2 needed) - Definitely will need these...
7.) 94050-08080 flange nut (8mm) ($0.08) (2 needed) - And I'll need these...
So I THINK I just need to buy the BSQ mounting kit (or beaks if I feel bling bling) and (2) 52308-SS0-000 bushing brackets, (2) 90175-ST7-Z00 bolts (8x35), and (2) 94050-08080 flange nuts (8mm)...
Right? Am I missing anything?
You do need #6 and #7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">5.) 52312-ST7-Z00 endlink bushing collar ($5.00) (4 needed) – Actually I only need 2, but either way, I already got these right? </TD></TR></TABLE>
You really do need four. I don't know why they do this, but they come in halves (2pc sleeves) even tho the original pieces are 1pc sleeves.
You also need a pair of swaybar endlink-to-rear LCA bolts and washers.
how about #3? I need the brackets right? that's what #3 is right?
and i thought #6 was the "swaybar endlink-to-rear LCA bolts and washers"
i also notice i'm missing the 4 bolts for the d-brackets...
oh and no beaks kit cuz i can get the bsq for free. Not to mention, if the bsq works great, i don't want to waste money on "extra" protection ($45 more expensive than bsq). i think the beaks kit does come with those 4 d-bracket bolts that I need though... but 4 bolts for $45 ($65 in my case)?
no thanks
no thanks
#3 - yes, you need.
#6 is for the BSQ mounting kit, but not for the Beaks mounting kit. It's coupled with #7 to secure the lower portion of the BSQ kit. You can always buy your own nut/bolt/washer combination, but the Honda stuff is pretty cheap anyways if you're going to order it all together.
The swaybar endlink-to-LCA bolts are M10x1.25 thread pitch. I don't know how long they are, but I'm guessing a two inch (50mm) bolt should work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tr0LL »</TD></TR><TR><TD CLASS="quote">found it locally.... the guy is actually on h-t also though...</TD></TR></TABLE>
yea, he bought it off of me! he lowballed for $100! hehe, all good!
Tr0LL
16
Jun 18, 2003 11:44 AM
ryanhook
May 8, 2003 11:58 AM
