sohc vtec head?
Old Jun 20, 2003 | 12:05 PM
hatch808's Avatar
Default sohc vtec head?
how can you tell if a head is vtec if there is no valve cover? also what parts will i need to make a 98 sohc vtec head fit on my 95 vtec block(ie: manifold, distributer, head gasket, valve cover)?
Old Jun 20, 2003 | 01:09 PM
ion_four's Avatar
Default Re: sohc vtec head? (#1REX)
Why are you swapping the head? There is only a slight difference in compression and the cam grind...in any case, just look for the VTEC solenoid on the passenger-side rear of the head. If the engine is a 98+ wouldn't it say VTEC on it, anyway?
You'll probably need the headgasket and maybe the dizzy, but that's probably all...
Old Jun 20, 2003 | 04:14 PM
Katman's Avatar
Default Re: sohc vtec head? (ion_four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">Why are you swapping the head? There is only a slight difference in compression and the cam grind...in any case, just look for the VTEC solenoid on the passenger-side rear of the head. If the engine is a 98+ wouldn't it say VTEC on it, anyway?
You'll probably need the headgasket and maybe the dizzy, but that's probably all...</TD></TR></TABLE>
also, the spark plugs are angled toward the exhaust side of the head....but the VTS should be a dead giveaway..
Old Jun 20, 2003 | 06:41 PM
Racer613's Avatar
Default Re: sohc vtec head? (hatch808)
also the engine codes on the block will tell you what model engine it is....
but if it has no head..its safe to say that it lacks vtec till you put a vtec head back on it.
The dead givaway is the vtec solenoid to the back left of the valve cover. behind the dizzy.
Old Jun 20, 2003 | 06:54 PM
ERA's Avatar
ERA
Doing a 98 head to a 95 block is going to be OBD1 to OBD2 as far as the head goes and I don't think you are going to be able to use the z6/zc IM either, its got to be 96 up also. You'll need the guts from a 95 dizzy... hint hint good luck
Old Jun 21, 2003 | 09:39 AM
Katman's Avatar
Default Re: sohc vtec head? (delslo26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo26 &raquo;</TD></TR><TR><TD CLASS="quote">Doing a 98 head to a 95 block is going to be OBD1 to OBD2 as far as the head goes and I don't think you are going to be able to use the z6/zc IM either, its got to be 96 up also. You'll need the guts from a 95 dizzy... hint hint good luck </TD></TR></TABLE>
actually you're kinda of wrong..
He can reuse his OBD1 electronics/ignition parts and intake manifold on the 98 head.
PushnFords
Honda Civic (2001 - 2005)
Jan 10, 2018 09:58 PM
Red-Rocket
Dec 17, 2013 03:13 AM
igo4bmx
Jun 30, 2004 12:27 PM
fearthegerbil
Jul 9, 2003 11:48 PM
hatch808
Jun 20, 2003 01:27 PM
