B16 build
Old Jun 17, 2003 | 10:51 AM
maxpsi's Avatar
Default B16 build
I have some questions for those that have built there B16. I was going get a new oil pump, water pump, etc. As with most B series parts, I have heard that you can interchange oil pump,etc. as a sorta OEM upgrade. I want to save money, so I thought some new OEM parts from a higher trim honda/acura vehicle would be a nice upgrade. Would parts did you use, or what would be an upgrade that would work?
Old Jun 17, 2003 | 11:23 AM
wm5holla's Avatar
Default Re: B16 build (maxpsi)
im still looking to
Old Jun 17, 2003 | 11:24 AM
Kamin's Avatar
Default Re: B16 build (wm5holla)
they are all the same.
just get the ones for your motor.
Old Jun 17, 2003 | 11:28 AM
maxpsi's Avatar
Default Re: B16 build (Kamin)
so you are saying that an oil pump made for a GSR, ITR, or CRV(2 liter block) is the same as the one for a 1.6 liter engine? I believe they may have changed it for larger blocks. I am looking into an oil pump, water pump, and maybe a thermostat as an OEM upgrade.
Old Jun 17, 2003 | 11:33 AM
turbo*s2k's Avatar
When you build your B16 most people and me for instance I bought a Type R oil pump. As for the water pump I'm not sure. My block was faily new so I didn't replace it. Most of the B-series stuff is interchangeble, but you should always double check. Hope that helps.
Old Jun 17, 2003 | 12:00 PM
94CivicSi's Avatar
Default Re: B16 build (TurboChrgd_Civic)
When I got my block, it was pretty used up, but the oil pump was well within the service limits. Check all the clearances inside and if yours is good, I wouldn't bother replacing it.
Get a B16 water pump. Select a thermostat appropriate for the climate you live in.
Old Jun 17, 2003 | 12:08 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">so you are saying that an oil pump made for a GSR, ITR, or CRV(2 liter block) is the same as the one for a 1.6 liter engine? I believe they may have changed it for larger blocks. I am looking into an oil pump, water pump, and maybe a thermostat as an OEM upgrade. </TD></TR></TABLE>
the blocks arent any larger. the oil galleys are the same size for vtec engines (as far as i know). the only diffrence is bore and stroke.
honda likes to use the same parts for everything. i would not be surprised if a ITR oil pump was the exact same as a b16 oil pump.
there is nothing wrong with the b16 oil pump, water pump or thermostat.
Old Jun 17, 2003 | 01:10 PM
maxpsi's Avatar
So there are no upgrades for any B series engine as far as OEM parts go with oil pumps, water pumps, thermostats, etc.?
Old Jun 17, 2003 | 01:31 PM
turbo*s2k's Avatar
The OEM stuff in most cases is the best stuff... It just depends on what your replacing & what kind of racing/driving your going to be doing...
fatboy803
Feb 11, 2010 09:48 AM
vtechjunkie
Jan 20, 2009 04:20 PM
WVTURBOCRX
Oct 8, 2006 04:30 AM
b16vtecsol
Nov 18, 2003 12:45 AM
BoostinDC2
Jan 17, 2002 12:34 PM
