does a minime need a 92-95 fpr
Old Jun 17, 2003 | 10:02 AM
Iceycrx's Avatar
Default does a minime need a 92-95 fpr
does a minime using a a6 intake manifold need a 92-95 fpr
Old Jun 17, 2003 | 02:41 PM
Iceycrx's Avatar
Default Re: does a minime need a 92-95 fpr (Iceycrx)
I have no damn clue why my minime wont work, so frustrated and pist off, Got fuel got spark from coil, and checked at plug wires, got compression 250ish across all cylinders. all the grounds and wires are pluged in distrib is mounted .....lost and pistoff.....suggestions?
Old Jun 17, 2003 | 03:37 PM
sicivic's Avatar
What is your problem? Do you have spark through the spark plugs? Is the distributor plugged in? What is your set-up? i.e. block, head, ecu, etc.
Old Jun 17, 2003 | 03:57 PM
USDM 4G VTEC's Avatar
for a VTEC head u gotta use the FPR of that specific head unles u use a Adj, FPR>...
the engine works ok with a A6 one..... but for more tunning and more power i say get the one for the head!!!!
Old Jun 17, 2003 | 04:14 PM
sicivic's Avatar
Default Re: does a minime need a 92-95 fpr (USDM 4G VTEC)
the 92-95 fpr isn't needed. I am using the stock A6 one with my Z6 head. The car runs plenty rich using a air/fuel ratio gauge. The car also put down 114.8hp at the wheels untuned. I'm also running a Fields SFC-Vtec controller which you tune the car with.
Old Jun 18, 2003 | 02:22 PM
Iceycrx's Avatar
Default Re: does a minime need a 92-95 fpr (sicivic)
yea i got the car running, no one mentioned the plug wires from an A6 won't work , never realized something that obvious but stress does that.
dylokjai
Mar 27, 2007 01:42 AM
EGdaveoner
Jun 14, 2005 10:13 PM
apexrift
Mar 18, 2005 12:47 AM
turbo_ef9
Mar 1, 2004 12:19 PM
