what would happen b18c head on a b16a block
Old Jun 16, 2003 | 09:16 PM
jdmbuilt's Avatar
Default what would happen b18c head on a b16a block
please don't ask why someone would do this.
but what would the ups and downs of this be?
thanks a lot.
Old Jun 16, 2003 | 09:22 PM
porsche997dc2's Avatar
Default Re: what would happen b18c head on a b16a block (jdmbuilt)
there's nothing wrong doing this setup. The head bolt in perfectly. Sometimes, you do what ever is available to you.
Old Jun 17, 2003 | 01:47 AM
pissedoffsol's Avatar
it will bump your compression about .2 points, and you would need the IM of the gsr as well, due to the different bolt patterns
Old Jun 18, 2003 | 08:07 AM
turbo*s2k's Avatar
Default Re: (pissedoffsol)
I know that you would use the head bolts from the GSR if you were using a GSR block, and a b16 or type r head. So I"m assuming in this case a B16 block with GSR head you would use the B16 head bolts correct?
Old Jun 18, 2003 | 11:49 AM
Kataku2K3's Avatar
Default Re: (TurboChrgd_Civic)
Yup, just use the B16A headbolts, they're meant for the 263mm block... As pissedoffsol said, you will get an increase of ~0.20:1 at std. bore... B16A with 81mm PR3 slugs ~10.4:1, with P30's ~10.6:1... Good Luck
Old Jun 18, 2003 | 12:05 PM
TodaCivic's Avatar
Default Re: (Kataku2K3)
I had that setup for a little while... sold the car like that too..eheh.
It gives alot more low end tq... something b16's need badly.
I removed the secondary butterflies since i had si ecu... it pulled nicely all the way to 8k.
I would say like the other guy said... you do what you can afford soemtimes.
4g4dcruisin
10
Sep 4, 2009 09:22 AM
nolicense526
Oct 15, 2007 10:46 PM
JALOP B16
Dec 31, 2002 02:17 PM
The Mole
Dec 5, 2002 09:29 PM
Euphoria81
Feb 21, 2002 07:41 AM
