need help bleeding clutch
Old Jun 16, 2003 | 07:27 PM
blklude's Avatar
Default need help bleeding clutch
I want to change clutch fluid but i need the process to do it. I know where to bleed and stuff but just don't know the step.
Thanks
Old Jun 16, 2003 | 07:37 PM
Behan's Avatar
Default Re: need help bleeding clutch (blklude)
i'm not sure if its in here but you might want to take a look.
http://www.icelord.net/honda/repair/
Old Jun 16, 2003 | 07:38 PM
AndyD's Avatar
From Superhonda.com
"the clutch will feel like it has no pressure and will go up and down very easily...and it won't go back up unless you lift it...
you will now have to bleed it...go buy one of the brake bleeding kit...3.99...looks like a little container with a top and a clear hose attached to it....loosen then bleeder screw located infront of the slave cylinder and attach the clear hose to it...fill the container with brake fluid and attach the tube there...make sure you keep the reservoir tank full at ALL TIMES when bleeding..have a friend pump the clutch a few times and you watch as the air bubble is being pumped out of your cylinder...have him lift the clutch slowly but push it down fast...so the air gets out...tell him to keep doing that till you no longer see any air bubbles coming out of the tube...as soon as you see no more air bubbles come out...immediately tell him to have the clutch pedal pressed to the floor and hold it there.....then tight up the bleeder screw....remember when bleeding ALWAYS have your reservoir tank full....or else air will get inside and you will have to start all over....it takes about 5 minutes to bleed it with the container...anyways when you tighten up the bleed screw....lift up the clutch pedal slowly...it will draw fluid into the system and will be hard to push back down with hand....when u feel like you have pressure in the clutch...bleeding is done...now reattach the fans and take your car for a test drive....it will be like new...smooth gears better for the clutch cuz you're not trying to force it in and wearing it out..."
I didn't use the bleeder kit and it worked fine.
Hope this helps.
Old Jun 16, 2003 | 08:10 PM
ultimatehonda's Avatar
I just did mine today....Best thing to do is suck out all the old fluid from the tank and pour new fluid in. Then have a friend sit in the car and press the clutch all the way down. Now open the bleeder screw and the fluid will come out. Then when it stops close the screw back up and tell you friend to release the pedal...you will notice the fluid in the tank will go down. Repeat this process untill new fluid starts to come out.
Old Jun 16, 2003 | 10:08 PM
blklude's Avatar
THANKS alot. I am greatly appreciated by you guys. I'm trying it tomorrow, I'm going to buy the bleed kit.
89sparks
Honda Motorcycles
May 24, 2020 05:27 AM
diviznrider
Feb 4, 2011 11:01 AM
RusBear
Jul 10, 2008 11:08 AM
knightlude
Jun 13, 2003 05:24 PM
PatrickGSR94
Dec 8, 2002 06:36 PM
