How to remove fuel hose from fuel rail on B16a?
Old Jul 22, 2001 | 01:59 AM
Lyonel's Avatar
Default How to remove fuel hose from fuel rail on B16a?
I've tried from positions 1 and 2 but it won't budge, I don't want to use excessive force as it might break it. Any suggestions?
BTW anyone know what this connector is for?
TIA
Old Jul 22, 2001 | 02:56 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: How to remove fuel hose from fuel rail on B16a? (Lyonel)
For the fuel line, you see that plactic cap on the end of the fuel rail? Pop it off and you will see a bolt under it, 12 mm I think. Just unbolt it and you should be able to slide it off...
art
Old Jul 22, 2001 | 05:34 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: How to remove fuel hose from fuel rail on B16a? (Arturbo)
no,no,no,no.
Use a big wrench and remove the end piece (has the milky plastic cap).
Old Jul 22, 2001 | 06:43 AM
Sonic's Avatar
Default Re: How to remove fuel hose from fuel rail on B16a? (B18C-EJ1)
yup - use a large wrench (7/8" works usually) and screw the end off...don't take the plastic cap off
Old Jul 22, 2001 | 07:01 AM
H22CIVIC's Avatar
New User
The connector is for your knock sensor.
Old Jul 22, 2001 | 07:08 AM
Big James's Avatar
New User
Default Re: How to remove fuel hose from fuel rail on B16a? (H22CIVIC)
It would have been easier to remove if you would have left the rail connected to the manifold. You can get better leverage.
Old Jul 22, 2001 | 11:59 AM
Lyonel's Avatar
Default Re: How to remove fuel hose from fuel rail on B16a? (Big James)
Thanks guys!
Old Jul 22, 2001 | 01:14 PM
accordking's Avatar
Please tell me that KNock sensor isn't broken. Cause if it is it will cost a pretty penny from the dealer. I about 2 in my tool box just in case I run into this problem.
Old Jul 22, 2001 | 02:32 PM
raene's Avatar
I see your website's called projectxsi... are you building your own JDM XSi integra? If so, neato .
Old Jul 22, 2001 | 05:36 PM
Lyonel's Avatar
Default Re: How to remove fuel hose from fuel rail on B16a? (raeneshadow)
I already have an XSi... just modding it
Ahknodd
Sep 4, 2006 05:13 PM
beoy9
Aug 22, 2006 04:52 AM
sleeperb16a
Sep 7, 2004 07:57 PM
White86CRXSi
Sep 2, 2004 12:05 PM
B18EG6
Jan 8, 2003 12:24 AM
