Tach not working...????
Old Jun 16, 2003 | 06:44 PM
element_1one's Avatar
Default Tach not working...????
I just installed a si cluster with tach for a 91 hatch to replace the dx one. i had an aftermarket tach hooked up with the wire patched into the wire coming out of the ecu. now my tach in my gauge cluster is not working??? any ideas? I checked all the connections, wiped em down, replugged everything back in and nothing. should i check if i'm missign wires??? if so, what wires??? my aftermarket tach works fine.
Old Jun 16, 2003 | 07:40 PM
Frosty_spl's Avatar
Default Re: Tach not working...???? (element_1one)
My friends does that. Why do you need 2 tachs anyway?
Old Jun 16, 2003 | 08:50 PM
Default Re: Tach not working...???? (Frosty_SPL)
I don't need two tachs. I need the tach in my dash to work, not the aftermarket one. but the tach in my dash is NOT working and the aftermarket one is. there is one wire missing from the smaller grey plug. should there be a wire in there?
PINKS
May 11, 2006 05:36 PM
99sibluehatchwitb16
Jan 26, 2006 12:47 AM
tcwcrxhf
Jan 25, 2005 05:37 PM
91glassycrx
Apr 6, 2004 03:59 AM
MattsHatch93
Dec 1, 2002 10:09 AM
