Smoke from the dipstick hole
Old Jul 22, 2001 | 12:07 AM
gsr355's Avatar
Default Smoke from the dipstick hole
What would cause smoke (oil burning smell) to come out of the dipstick hole? I have the Greddy turbo kit and because the manifold is touching the dipstick hole, it melted the rubber on the dipstick, causing it to not seal properly. The past two week, whenever i would drive on the freeway, smoke would just fill up the whole cabin and set out a whole trail of smoke. It was so bad that i had to get a tow to get my car home. I thought it was oil dripping onto the downpipe and smoking, but after looking under the car, that doesn't seem to be the problem. Today, i was watching the car idle and saw a hint of smoke coming from the dipstick hole. While revving it to about 4k rpm, smoke just bellowed out of that hole. What's causing this. Will over filling the oil do this. I was probably 3/4 of a quart over the full mark because of my faulty dipstick. Is this what usually happens when the oil level is too high. Any clues? How much smoke usually comes out from that hole? I'm not going to run a dipstick anymore, i plugged up that hole with a long screw.
Old Jul 22, 2001 | 12:45 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Smoke from the dipstick hole (gsr355)
First go invest in a CRV dipstick, they're shielded from the heat, then get an oil change and refill the engine correctly.
Duhul
May 20, 2010 11:18 AM
KiNG $h!t
Jan 28, 2005 08:50 AM
Nfurno
Sep 14, 2002 10:58 PM
myNAteq
Oct 17, 2001 06:12 PM
gsr355
Jul 24, 2001 11:00 AM
