Smoke out out dipstick hole
Old Jul 22, 2001 | 12:05 AM
gsr355's Avatar
Default Smoke out out dipstick hole
What would cause smoke (oil burning smell) to come out of the dipstick hole? I have the Greddy turbo kit and because the manifold is touching the dipstick hole, it melted the rubber on the dipstick, causing it to not seal properly. The past two week, whenever i would drive on the freeway, smoke would just fill up the whole cabin and set out a whole trail of smoke. It was so bad that i had to get a tow to get my car home. I thought it was oil dripping onto the downpipe and smoking, but after looking under the car, that doesn't seem to be the problem. Today, i was watching the car idle and saw a hint of smoke coming from the dipstick hole. While revving it to about 4k rpm, smoke just bellowed out of that hole. What's causing this. Will over filling the oil do this. I was probably 3/4 of a quart over the full mark because of my faulty dipstick. Is this what usually happens when the oil level is too high. Any clues? How much smoke usually comes out from that hole? I'm not going to run a dipstick anymore, i plugged up that hole with a long screw.
Old Jul 22, 2001 | 03:35 AM
woong's Avatar
Default Re: Smoke out out dipstick hole (gsr355)
my car does that all the time
Old Jul 22, 2001 | 10:02 AM
98Psi ITR's Avatar
same thing happened to me, I thought my damn car was on fire! jk, but anyway , I just replaced the dipstick off another honda, keepiing the original to check the oil. So far so good.
Old Jul 22, 2001 | 10:53 AM
TurboInteg95's Avatar
I think you might want to do a compression check. smoke coming out of the dipstick hole means there's compression getting into the crank case. you might have a bad ring or something. does is smoke at all out of the exhaust?
Old Jul 23, 2001 | 11:18 AM
gsr355's Avatar
compression test came out to be 215, 205, 205, and 205
woong, what did you to to solve the problem?
Old Jul 23, 2001 | 08:12 PM
GRoceryTurbo's Avatar
https://honda-tech.com/zerothread?id=53383
Same here, please help I hate putting in new dipsticks every couple of months.
Old Jul 23, 2001 | 09:27 PM
gsr355's Avatar
i solve the problem, i just took a old metal rod about the size of the dipstick hole with a 90 degree bend and stuck it in the hole. I keep a new dipstick in the trunk in case i need to check oil levels. So now, no more dipstick to burn and no smoke coming from that hole.
Old Jul 24, 2001 | 11:00 AM
C-speed's Avatar
A 'minute' trace of smoke from the dipstick hole is normal. Excess smoke means there is a problem. This is caused by blow-by. Something is wrong with the pistons or rings.
A compression test will NOT tell you that something is wrong. It may give good comp. results, yet you still have an issue where the rings aren't sealing properly, etc etc.
The only way to know for sure is to do a leak down test.
Duhul
May 20, 2010 11:18 AM
KiNG $h!t
Jan 28, 2005 08:50 AM
Nfurno
Sep 14, 2002 10:58 PM
myNAteq
Oct 17, 2001 06:12 PM
gsr355
Jul 22, 2001 12:45 AM
