Heater doesn't work!!!
Old Jun 16, 2003 | 05:33 PM
CereaLand's Avatar
Default Heater doesn't work!!!
I have the 96-98 climate controls. When I push the control from cold over to the heat, It still blow out Cold air. It worked before, but now it just suddenly stop working. My heater doesn't turn on. Any clues to the problem?
_______
Old Jun 16, 2003 | 06:37 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Heater doesn't work!!! (CereaLand)
check under the dash for a cable that connects to the box under behind the middle of the dash/console. that may have come undone. if that is connected, when you slide the switch you should hear a flap behind the dash that you are switching/opening. also check the valve/cable connection in your engine bay against the firewall.
pmp
25
Oct 5, 2011 09:13 PM
integradc4_rg87
Oct 29, 2010 11:51 PM
navin
Dec 16, 2007 10:04 PM
90crxterror
Sep 5, 2005 03:16 PM
sleepin91teg
19
Mar 14, 2005 08:37 PM
