Heater doesn't work
Old Jun 16, 2003 | 05:30 PM
CereaLand's Avatar
Default Heater doesn't work
I have the 96-98 climate controls. When I push the control from cold over to the heat, It still blow out Cold air. It work before, but now it just suddenly stop working. My heater doesn't turn on. Any clues to the problem?
Old Jun 16, 2003 | 05:33 PM
tsands's Avatar
Default Re: Heater doesn't work (CereaLand)
can you feel the control switch open and close when you move it? the actual lever that allows cold or hot air is under the dash by steering wheel, or was on my car. sometimes the lever came off the tracks.
Old Jun 16, 2003 | 05:41 PM
CereaLand's Avatar
Default Re: Heater doesn't work (tsands)
Hmm, thanks I will have to open it up and check this sunday.
Any other suggestions?
Old Jun 16, 2003 | 05:51 PM
Nextelbuddy's Avatar
my freind had the same problem and it was the cables domeing off the tracks. check that first. good luck
Old Jun 16, 2003 | 05:56 PM
poison's Avatar
I would have a friend sit inside the car and watch the heater valve to see it if opens and closes.
Old Jun 16, 2003 | 07:44 PM
CereaLand's Avatar
Default Re: Heater doesn't work (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">my freind had the same problem and it was the cables domeing off the tracks. check that first. good luck</TD></TR></TABLE>
If the cables came off of the track, is it easy to fix? Just stick the cables back on?
Old Jun 16, 2003 | 07:45 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CereaLand &raquo;</TD></TR><TR><TD CLASS="quote">
If the cables came off of the track, is it easy to fix? Just stick the cables back on?</TD></TR></TABLE>
Yep, you have it.
itr1448
Feb 18, 2010 09:31 PM
xKAMILxEK
Dec 3, 2009 08:42 PM
TaDLaD
Oct 1, 2009 11:31 AM
dohc-father
Jan 21, 2009 08:47 AM
blakacintegra
Dec 6, 2006 06:55 AM
