map sensor going off at like 1.5psi??
Old Jun 16, 2003 | 04:26 PM
Neukin's Avatar
Default map sensor going off at like 1.5psi??
b16a jrsc obd1 ecu ect with obd0 map sensor. at like 1.5psi the CEL comes on 3blinks...?? what do i do to fix this. thnaks
Old Jun 16, 2003 | 04:29 PM
turbochic's Avatar
Default Re: map sensor going off at like 1.5psi?? (toyosupr)
you need a missing link
its a spacer? that has a little pin thingy that pushes out when there is boost it goes between the throttle body and map senser that doesnt allow the sensor to read boost
Old Jun 16, 2003 | 05:24 PM
Neukin's Avatar
Default Re: map sensor going off at like 1.5psi?? (fmaxturbochic)
ya iv installed them before but i didnt think you needed them for the jrsc kit?? why wouldnt it comewith the kit if you needed it?? o-well more ideas
sixfourkiller
Jan 3, 2011 09:36 AM
c_trick
May 29, 2010 07:06 PM
rice a roni
Sep 16, 2005 10:37 AM
Desperado
Feb 3, 2004 09:39 AM
