Car has jumpy idle... what to check for?
my cars idle goes up and down constantly from 2k rpm down to like 700..
what should icheck for
car = 1991 crx si
motor = d16z6 with d16z6 intake manifold...
ecu = pm6 ecu.
car = 1991 crx si
ecu = pm6 ecu.
Okay, on Z6 intake manifolds, there is a FIV(fast idle valve) on the bottom of the throttle body. Take your throttle body off. You will see two screws on the side. Undo those 2 screws. Then inside there is a little clip, a lot of times they come out and will cause your idle to be messed up majorly. A way to check this is to stick your finger in your throttle body and cover up one of the holes in there(i think its the one on the bottom closest to the motor), and if it stops the idle from fluctuatiing that is the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CimorelliCRX »</TD></TR><TR><TD CLASS="quote">Okay, on Z6 intake manifolds, there is a FIV(fast idle valve) on the bottom of the throttle body. Take your throttle body off. You will see two screws on the side. Undo those 2 screws. Then inside there is a little clip, a lot of times they come out and will cause your idle to be messed up majorly. A way to check this is to stick your finger in your throttle body and cover up one of the holes in there(i think its the one on the bottom closest to the motor), and if it stops the idle from fluctuatiing that is the problem.</TD></TR></TABLE>
Is that the same on a b18c?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">first thing to check for would be vacuum leaks...</TD></TR></TABLE>
Leviatard
18
Oct 30, 2014 09:28 AM
RaistlinJDM
Apr 21, 2014 06:10 PM
blindsk8er1013
Sep 6, 2005 07:32 PM
hatch808
Jun 9, 2003 03:56 PM
