help stripped oil pan nut
Old Jun 16, 2003 | 01:43 PM
linx's Avatar
Default help stripped oil pan nut
the nut that holds my oil pan to the block is stripped(not the drain plug) It wont tighten it just spins so its stuck on the stud and i cannot remove it. I was thinking of cutting with a dremel but what bit do i use as theres no room its the one by the transmission.
Old Jun 16, 2003 | 01:49 PM
4drEF's Avatar
Keyboard Humorist
Default Re: help stripped oil pan nut (linx)
Can you grab it with pliers and pull while turning? I find that sometimes I can get nuts to grab threads this way.
Alternatively, you could remove the stud that the nut is on.
Old Jun 16, 2003 | 01:58 PM
linx's Avatar
Default Re: help stripped oil pan nut (4drEF)
when the pliers is on i cant turn it no room
Old Jun 16, 2003 | 06:00 PM
Blaze45's Avatar
Brrraaaap!
What you need to do is, do whatever it takes to get the bolt out, then pull out the drain plug, remove metal shavings that are in the oil pan threads and then screw in a NEW OEM oil drain plug. thats what I did on my Bro, inlaws car.
Good luck
Justin
Old Jun 16, 2003 | 07:13 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by linx &raquo;</TD></TR><TR><TD CLASS="quote">the nut that holds my oil pan to the block is stripped(not the drain plug) It wont tighten it just spins so its stuck on the stud and i cannot remove it. I was thinking of cutting with a dremel but what bit do i use as theres no room its the one by the transmission. </TD></TR></TABLE>
Old Jun 16, 2003 | 07:21 PM
crx98's Avatar
drill it out... then retap it, kinda alot of work.. but thats the only way if it cant get out any other way..
Old Jun 16, 2003 | 09:15 PM
Blaze45's Avatar
Brrraaaap!
Default Re: help stripped oil pan nut (nine0eight)
to me, I read it to fast. Sorry.
1drivinmofo
Mar 10, 2010 05:16 PM
XvPreludevX
Jun 20, 2009 02:10 PM
iukaman
Jan 12, 2008 06:39 PM
stareatsun
Nov 18, 2004 08:23 PM
turbohf
Feb 16, 2003 10:20 PM
