anyone have an ek hatch with a Si sohc motor in it?
Old Jun 16, 2003 | 11:06 AM
mixxed's Avatar
Default anyone have an ek hatch with a Si sohc motor in it?
as the topic says..
and it doesnt matter whether it is a stock/modded engine. I want to know what you think about it.....
thanks.
Old Jun 16, 2003 | 11:10 AM
YumVTEC's Avatar
Default Re: anyone have an ek hatch with a Si sohc motor in it? (mixxed)
Si's from 1986 or 1987 through 1995 had SOHC motors in them. The only realistic motor to use would be the d16z6 (SOHC VTEC) from a 1992-1995 Civic Si/EX, but it would be a PITA to convert the motor to OBD2. Might as well put in a d16y8 (SOHC VTEC) from a 96-00 Civic EX.
Old Jun 16, 2003 | 11:22 AM
mixxed's Avatar
Default Re: anyone have an ek hatch with a Si sohc motor in it? (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Si's from 1986 or 1987 through 1995 had SOHC motors in them. The only realistic motor to use would be the d16z6 (SOHC VTEC) from a 1992-1995 Civic Si/EX, but it would be a PITA to convert the motor to OBD2. Might as well put in a d16y8 (SOHC VTEC) from a 96-00 Civic EX.</TD></TR></TABLE>
Yes thats what i was thinking. The 92-95 gen Si SOHC would be best....BUT it is OBD1 so im a bit confused to what you were saying about converting????
anyway...im really curious about the gains from having this done.
i know its not your typical b16a or b18c etc etc but im still very curious/interested in knowing the power gains, 1/4 times from it....
BUMP..
Old Jun 16, 2003 | 11:41 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixxed &raquo;</TD></TR><TR><TD CLASS="quote">
BUMP.. </TD></TR></TABLE>
ek is obd2. d16z6 is obd1. get a d16y8 (96-00 ex) engine so it'll be easier to wire up. you asked about gains. well... lets see... more power. that's about it. you should already know that the dx engine has 106 hp and ex has 127. i have a d16y8 in my 97 hatch.
Old Jun 17, 2003 | 11:45 AM
mixxed's Avatar
Default Re: anyone have an ek hatch with a Si sohc motor in it? (civicdxtyper)
bump...
anyway....if you are swaping the 92-95 Si sohc motor into an ek what do you need to do it? Do you need to get a new ecu (what else is there?) as well? or can you just drop the Si sohc motor straight in and go?
Old Jun 17, 2003 | 11:51 AM
Nextelbuddy's Avatar
you are going to need a obd2 distributor, obd2 injectors, obd2 altenator, and obd2 wiring harness, and hopefully some one else will chime in and say what else is needed
Old Jun 17, 2003 | 11:58 AM
silverEH2's Avatar
Default Re: anyone have an ek hatch with a Si sohc motor in it? (nextelbuddy)
loved my sohc vtec motor
Old Jun 17, 2003 | 12:13 PM
mixxed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">you are going to need a obd2 distributor, obd2 injectors, obd2 altenator, and obd2 wiring harness, and hopefully some one else will chime in and say what else is needed</TD></TR></TABLE>
thanx bro..
BUMP
Old Jun 19, 2003 | 05:38 AM
mixxed's Avatar
bump...
sorry can someone please help me out and confirm what exactly i need? PLEASE.
thanks a lot
Old Jun 19, 2003 | 03:15 PM
vladd's Avatar
can't you just repin the obd1 distributor to obd2 specs? also, i thought the alternator was the same on obd1 and obd2.
Old Jun 19, 2003 | 05:10 PM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">
can't you just repin the obd1 distributor to obd2 specs? .</TD></TR></TABLE> yes it is very very simple.
also, i thought the alternator was the same on obd1 and obd2.</TD></TR></TABLE> no, the connector inside th ealternator is very different... you cannot repin the engine harness alternator plug easily, you will need to bust out the soldering iron.
lion-o
18
Nov 15, 2007 09:45 PM
stonedheckler
Sep 27, 2006 12:08 PM
h23 milano red
Mar 31, 2004 08:12 AM
ratherskate
Dec 14, 2003 05:05 PM
wu tang
30
Jun 16, 2002 01:28 AM
