lossing top end
Old Jun 16, 2003 | 09:03 AM
machine4321's Avatar
Default lossing top end
at the track last week i noticed that righ around 7000 to 7200 rpm i was losing power not like a bog but more jut fall off.....and ive noticed that the car doesnt rev as easy as it used to back in the day ...compression is still good check it every other week(220 to 225 on all 4 )
Old Jun 16, 2003 | 11:49 AM
up
Old Jun 16, 2003 | 12:52 PM
Elkins911's Avatar
Default Re: lossing top end (machine4321)
fuel filter. air filter. clogged injectors. blinker fluid. flux compasitor.
Old Jun 16, 2003 | 12:54 PM
soul.slinger's Avatar
Default Re: lossing top end (Elkins911)
steering wheel fluid
Old Jun 16, 2003 | 12:56 PM
Elkins911's Avatar
Default Re: lossing top end (soul.slinger)
do you have fuel injected spark plugs??? if you do, you need to make sure they are firing properly.... usually when they act up you have a problem though....
Old Jun 16, 2003 | 01:09 PM
2point6's Avatar
piston return springs are worn and need adjustment.
seriously, there can be any number of things leading to your slower reving. Try a basic tune-up first. Then an O2 sensor would be a good thing to change if it has been a while. then valve adjustment.
Old Jun 16, 2003 | 04:44 PM
thanks 2.6 to the other two guys go ***** up someone elses thread ********
every thing was checked last month o2 was done in nov of last year but my car runs very rich so mabye its time for a new one
what about fuel pum car has 300 000 kilometers on it and its stock
Old Jun 16, 2003 | 04:58 PM
3gdude's Avatar
Default Re: (machine4321)
O2 sensor is not even in the picture at 7K RPM, in open loop. Check fuel pressure at WOT or monitor O2 sensor volts at point where it's falling off...3gdude
Old Jun 16, 2003 | 05:06 PM
Mikeyslude's Avatar
Default Re: (3gdude)
at 86K my stock fuel pump and ignition both took a dump.
EFb18b
Aug 2, 2015 04:28 PM
alexm
Sep 12, 2008 03:42 PM
keviiinnnnn
15
May 9, 2008 12:14 PM
lowered94accord
Apr 26, 2007 04:29 PM
MidwestSi
Jun 23, 2005 05:43 AM
