HELLPP!!!
HELLPP!!!
Okay so i have 2 codes
P0170
and P0171(Pending)
I just replaced both my o2 sensors with Honda Replacement o2 sensors from honda
The engine is pretty much bone stock
just an intake is the only upgrade.
i have replaced all of the following in the past 2 months
fuel filter
spark plug wires
pcv valve
oil
oil filter
spark plugs
cap and roter
both o2 sensors
So if anyone knows what could be wrong or could give me a point in the right direction i could look in i would greatly appreciate it
P0170
and P0171(Pending)
fuel filter
spark plug wires
pcv valve
oil
oil filter
spark plugs
cap and roter
both o2 sensors
Re: HELLPP!!! (keviiinnnnn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keviiinnnnn »</TD></TR><TR><TD CLASS="quote">Okay so i have 2 codes
P0170
and P0171(Pending)
fuel filter
spark plug wires
pcv valve
oil
oil filter
spark plugs
cap and roter
both o2 sensors
So if anyone knows what could be wrong or could give me a point in the right direction i could look in i would greatly appreciate it</TD></TR></TABLE>
I agree with the other guy, sounds like it could be a vacumm leak.
Whats the fuel pressure look like?
P0170
and P0171(Pending)
fuel filter
spark plug wires
pcv valve
oil
oil filter
spark plugs
cap and roter
both o2 sensors
Re: HELLPP!!! (wonder squirrel)
I checked the injectors
they all seem to be normal.
they all spit out the same amount of gas.
i checked fuel pressure
it meets stock specs.
i keep hearing a vac leak coming from the intake man.
i replaced the line from the mani. to the pcv valve. it had a hole on it
and i can still hear the noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keviiinnnnn »</TD></TR><TR><TD CLASS="quote">I checked the injectors
Sounds like you found your problem, a vacumm leak. You just need to pin point where its at now
I'd work backwards. When did the problem show up? What did you do before the problem showed up? Can you UNDO whatever you did before this happened, and if so does it still happen?
If you added something . . .
I'd put the old ones back on and see what happens.
Re: HELLPP!!! (TahitianEG)
Well before i was getting the Code from the o2 sensors.
So i replaced both.
Now that code is gone
and i only have the running lean one's
So i replaced both.
Try to spray some brake cleaner around the IM. See if its maybe the IM gasket. I don't know,give it a try.(This is for your vacuum leak problem)
get a can of carbeurator cleaner and spray it around the intake manifold and vacuum lines with the engine running. when the idle speed changes and you hear a loud sucking sound that is where the vacuum leak is. It's almost definitely a vacuum leak causing the lean codes if your fuel pressure is good and your fuel injectors aren't clogged. If you just put an intake manifold on it the manifold gasket could be the leak.
Re: HELLPP!!! (tallboy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallboy69 »</TD></TR><TR><TD CLASS="quote">get a can of carbeurator cleaner and spray it around the intake manifold and vacuum lines with the engine running. when the idle speed changes and you hear a loud sucking sound that is where the vacuum leak is. It's almost definitely a vacuum leak causing the lean codes if your fuel pressure is good and your fuel injectors aren't clogged. If you just put an intake manifold on it the manifold gasket could be the leak.</TD></TR></TABLE>
This sounds accurate to me. Also be sure to check the EGR valve
Modified by wonder squirrel at 1:21 PM 5/9/2008
joaodossantos
06-09-2007 08:18 PM
