HELP!? weird noise!!
Old Jun 16, 2003 | 04:31 AM
kha's Avatar
kha
Default HELP!? weird noise!!
i just picked up my integra gsr 1998 a few days ago..
the car runs nice and very strong. but i cant but notice a rattling/jingling noise?
it happens often when im shifting or cruising with rpm's aroun 3 sometimes lower and sometimes higher..
im thinkin since the car the completely stock it could be the HEAT SHIELD?
im not sure but does anyone have answers?
Old Jun 16, 2003 | 08:55 AM
JimBlake's Avatar
Default Re: HELP!? weird noise!! (kha)
It could be any of the exhaust heatshields. They're easiest to check.
It could be the A-pipe rattle, that's a double-wall pipe. The inner tube buzzes against the outer. This sounds pretty common, search this BB for more information.
It could even be the ceramic guts of the cat being broken & rattling.
Old Jun 16, 2003 | 09:00 AM
AWDxBOOST's Avatar
Default Re: HELP!? weird noise!! (JimBlake)
id say one of the heat shields like he said....its easy to check, so start w/ that
Old Jun 16, 2003 | 09:41 AM
brucie's Avatar
hmm i have the same problem with my 96 gsr...noise happens only between 3-4k rpm... my cousin told me that it was my A-pipe after he checked it out... he's a service tech for honda ...well he said the cheapest way to replace it was to get a header...which i did and it solved the problem...then about 7 months later i hear the noise again!!!! same problem i am thinkin...its annoying! but maybe it could be something else as what u guys mentioned ....
Old Jun 16, 2003 | 09:50 AM
civic91's Avatar
Default Re: HELP!? weird noise!! (brucie)
what kind of header did you get and how much did you pay for it? I have the same problem and told its my A pipe, but some said it might be the heatshield. My question is, if it is the heatshield, is there any other way to solve the problem than removing the heatshield? Just wondering. I'm not sure if I want to remove all my heatshield because I believe there's a purpose why they put the heatshield there.
Thanks a lot
Old Jun 16, 2003 | 12:39 PM
JimBlake's Avatar
Default Re: HELP!? weird noise!! (civic91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">... My question is, if it is the heatshield, is there any other way to solve the problem than removing the heatshield?</TD></TR></TABLE>
First you gotta find the rattling. There's heatshields bolted to the cat, some more bolted to the B-pipe, and even more bolted to the underside of the floorpan. There's a zillion ways for them to fail, you just have to look.
Sometimes the bolts holding the heatshield are just loose. Tighten them, use some locktite or something... Sometimes the heatshield rusts off. If the bolt hole has rusted so big that it just falls off, you might use a fender washer to hold it back on. Or a hose clamp. If the heatshield is all rusty & dark colored, it's not working anyway, so you need a shiny new one.
Old Jun 16, 2003 | 12:46 PM
VTECorona's Avatar
Heres what I did when I was in ur EXACT situation...
Take a broom stick and bang it against the heatshield on your catalytic converter and the heatshield that goes over your B-pipe right after the cat. Mine were both rattling so I called acura and they said it was fine to remove.. Its been a year no and I've had no problems, just don't park over leaf piles.
Try a search next time boss, this topic is covered like twice a day. Literally.
Old Jun 17, 2003 | 10:26 PM
bOOsTiNSoHcVtEc's Avatar
Default Re: HELP!? weird noise!! (97RedTegGSR)
i have the same noise at about 3k rpms...so did u take off the heat shield??
Old Jun 17, 2003 | 11:04 PM
JadeDM's Avatar
what kinda rattling are you hearing is it when you accelerate slowly? i think i have the same problem but it sounds like its coming from the engine?
Old Jun 25, 2003 | 11:51 AM
brucie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of header did you get and how much did you pay for it? </TD></TR></TABLE>
r-1 header(paid $155 for it haha)...but i went under my car to check and it wasnt my header...it was my heatshield... it was cracked...i just took the heatshield out and no more noise... hope u guys fix ur problem! take carez
Old Jun 25, 2003 | 04:59 PM
iiilgsrlll's Avatar
Its most likely the A-Pipe (downpipe) part of the header. Removed mine and rattle went away.
gohonda
Oct 15, 2007 03:48 PM
newbie415
Sep 21, 2007 04:16 PM
easyFOsheezy
Jun 30, 2005 02:29 PM
brickonwheels
Jul 7, 2004 06:04 PM
VieTec
Aug 15, 2002 12:38 PM
