new timing belt at 30k?
Old Jun 15, 2003 | 06:38 PM
1hotintegra's Avatar
Default new timing belt at 30k?
im gettin the head redone and i was wondering if i should do the timing belt since it only has 30k miles on it?? what about the water pump.. im kinda low on funds but when i hit 90k im sure i'll have money... but should i do the belt and not the pump??
Old Jun 15, 2003 | 09:40 PM
xteg95's Avatar
Default Re: new timing belt at 30k? (1hotintegra)
not at 30k...save the money, or you can inspect it yourself for cracks.
Old Jun 16, 2003 | 01:24 AM
venom's Avatar
if you're really worried about it...do it..t-belts are cheap and if you have the head off..it's a prime time to do it..hell do the water pump too.
Old Jun 16, 2003 | 01:41 AM
NA gs-R 05 C
Guest
Posts: n/a
i say you should do the belt cause once the belt is takin off, it is weaken wen u put it back on, so just be on the safe side, change the belt.
Old Jun 16, 2003 | 04:42 AM
nek0's Avatar
follow the = don't fix it if it ain't broke.
Timing belts last more then 100k but it's good to change about 80-90k. Just visually inspect it. Water pump, I doubt it's bad unless your car is overheating or something.
Old Jun 16, 2003 | 05:40 AM
Stewie's Avatar
Default Re: new timing belt at 30k? (nek0)
You don't need to take the timing belt off to remove the head. Just slide it off the cam spockets. Anyways, don't get a new timing belt even if you do take it off. An oem timing belt is $50! That's just a waste of money.
Old Jun 16, 2003 | 08:24 AM
andrewM's Avatar
Default Re: new timing belt at 30k? (Mac8008)
a new belt is a waste of money (unless the one u got on worn already) and a new water pump is a big waste of money a 30k.
Old Jun 16, 2003 | 10:13 AM
JL 74's Avatar
25 Year Member
Default Re: new timing belt at 30k? (andrewM)
just visually inspect it.
Old Jun 16, 2003 | 11:25 AM
stegs's Avatar
How much was the head work? 50 bucks is a small price to pay for insurance, labor down the way....
Old Jun 16, 2003 | 12:31 PM
venom's Avatar
Default Re: new timing belt at 30k? (stegs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stegs &raquo;</TD></TR><TR><TD CLASS="quote">How much was the head work? 50 bucks is a small price to pay for insurance, labor down the way....</TD></TR></TABLE>
that's kinda what I'm trying to say...but whatever
Old Jun 16, 2003 | 12:32 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: new timing belt at 30k? (venom)
yah you should definatnly "splurge" and pay $50
Old Jun 16, 2003 | 02:21 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by venom &raquo;</TD></TR><TR><TD CLASS="quote">if you're really worried about it...do it..t-belts are cheap and if you have the head off..it's a prime time to do it..hell do the water pump too.</TD></TR></TABLE>
yeah, then you don't have to change it until 120k....
Old Jun 16, 2003 | 02:44 PM
IntEGNYC's Avatar
What does getting the head redone mean? at 30k you should be fine with the minor scheduled tuneup.
I would suggest leaving the car as is. Your timing belt should be good for another 75k at least. Probably not worth $ IMHO.
If you do decide to go ahead, use with OEM parts.
Old Jun 16, 2003 | 03:10 PM
type r 01-1063's Avatar
Changing the timing belt at 30K is overkill if it is still in good condition. Although, it won't hurt to change it. Keep in mind that if the timing belt fails you are looking into expensive repairs.
Somebody says its $50 for a new OEM. If I were in your shoes, I'd replace it. Cheap insurance and for peace of mind IMO.
dj-t
Feb 20, 2012 07:13 PM
chahsiubow
Dec 14, 2007 10:01 PM
tomcool
May 14, 2007 08:40 PM
honda94accord
Apr 10, 2007 05:39 AM
