valvetrain clatter........ or the "honda tap"
ok guys...... sooo how much is tooo much tapping?? i mean after my car warms up it has a noticable clattering sound in the valvetrain but it seems like every honda has the same kind of tapping sound....... even my parents 02crv does it with 15k on the odometer. should i just get my valves adjusted??? thanx for any input
The injectors are known to be loud, its called the famous Honda tick. But if its really loud it could be your valves. Take a screw driver and put it against your valve cover, then to your ear. You can determine where its coming from by doing this.
im running a dualcam zc right now.......... man i never thought it would be the injectors................ soo the injectors would be louder after the car warms up??? i will try this screw driver test......... thanx for ur input guys
I would say that could be your "Lost motion".
My self and a lot of my friend have noise coming from the "lost motion".
We all have head from 1 gen. B16...
It is more noisy when cold...but once warmed,the noise is still present....but mine is noisy since I have it(already 2 years and I'm doing track time + I rev easily everyday) so I don't see a problem unless you spent all your time on a racetrack running at high rev(+9k) for ~2 hours....
ok first off,check your valve clearance.second some older hondas that have the famous ticking noise is because there was a defect in the rocker arms.they were not the right temper material and the make a ticking sound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">"Lost motion"...hmmm im lost. haha. Please fill me in?</TD></TR></TABLE>
The VTEC rocker arms in VTEC engines don't do anything until VTEC is engaged, they just sit there rattling away, the "Lost Motion Plungers" are like little hydraulic shox that stop them moving about when they not in use, the wear a bit and the rattling gets louder, not a big worry
get it looked at quickly, dont be dumb like me, the lock nut and stud that is used to adjust clearance busted on mine and i found two of them rattling around in my head. lucky no further damaged occurred. anyone know how i go about replacing them?
i did the screw driver to ear test and all is pretty damn quiet inside the valvecover considering all the motion that goes on inside........ i also did the test on the injectors that were loud as hell and were coinciding with the ticking noise......... thanx for the input but i may have my valves adjusted to be safe......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxste »</TD></TR><TR><TD CLASS="quote">
The VTEC rocker arms in VTEC engines don't do anything until VTEC is engaged, they just sit there rattling away, the "Lost Motion Plungers" are like little hydraulic shox that stop them moving about when they not in use, the wear a bit and the rattling gets louder, not a big worry</TD></TR></TABLE>
Every B16A1 that has alot of mileage has this problem. The tapping goes away while in VTEC. Not really bad, just annoying and expensive to fix.
turbotime
Oct 8, 2005 09:02 PM
silentblackhat
17
May 25, 2005 09:15 AM
Full Race A6
19
Jun 26, 2004 01:31 PM
