Does the VSS affect vtec???
Old Jun 14, 2003 | 02:46 PM
crxtreme27's Avatar
Default Does the VSS affect vtec???
Ok, i tried wiring the vtec on my b16a and i dont hear or feel anything... however my check engine light is on and its giving code 17 which is the VSS... i dont know why its giving that code because the spedometer still works fine... i did check the speedo cable and its lose, it doesnt have the clip for the cable to stay in place but it doesnt come out..
any help??
thanks
Old Jun 14, 2003 | 03:08 PM
bossman032's Avatar
NO vtec if VSS code 17.
GET THE CLIP steal one or something.. or borrow..
reset ecu and if gives 17 again change the cluster!!!
Old Jun 14, 2003 | 03:13 PM
blah13's Avatar
Default Re: (bossman032)
VTEC wont engage under 20 or 25 mph so yes it would affect it as said above.
Old Jun 14, 2003 | 03:18 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Before you replace the cluster, make sure this screw is in and tight.
The screw in the red circle.
Make sure also that ALL the screws on the back of the cluster are there.
Old Jun 14, 2003 | 05:11 PM
bossman032's Avatar
Default Re: (Spaceballs the lunch box)
ahhhh **** that screw is that caused all my drama. I think that **** is the grond wire or something..
Old Jun 14, 2003 | 05:24 PM
No Big Whoop
That screw is what sends the VSS signal to the ECU.
Without it, no VTEC on stock ECU's
Old Jun 14, 2003 | 05:27 PM
Creepshow S60's Avatar
what's VSS? just a guess...but is it "variable ??? sensor"?
Old Jun 14, 2003 | 06:40 PM
thaiphob's Avatar
Nikon!!!
Default Re: (y-49CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX &raquo;</TD></TR><TR><TD CLASS="quote">what's VSS? just a guess...but is it "variable ??? sensor"?</TD></TR></TABLE>
vehicle speed sensor
Old Jun 15, 2003 | 11:38 AM
crxtreme27's Avatar
Thanks guys, i will check out the cluster and try to get a clip for the cable... i hope that fixes my problem... i still havent heard vtec on this car and im anxious to see what it can do... hehe... one more question, if that screw on the cluster wasnt in and tight, shouldnt the speedometer on the cluster not work??? my cluster still reads the speed...
Old Jun 15, 2003 | 01:58 PM
bossman032's Avatar
Default Re: (crxtreme27)
The Cluster will work fine speedometer.
Only it will throw the VSS because the ECU can’t find the signal.
You should be fine after you get the pin and tight that screw on the Cluster.
That was my problem I just realize that because I saw that screw was lose
I bought a new cluster
Old Jun 15, 2003 | 01:59 PM
No Big Whoop
Your speedometer works directly off the speedo cable.
That screw has no effect on the speedometer.
It is there only to connect the VSS inside the speedometer with the ECU.
Old Jun 15, 2003 | 06:53 PM
crxtreme27's Avatar
Ok, i placed the pin in there, but it seems not to be stayin in place... i tightned all the screws on the back and its still throwing me a code.. mynext step is to replace the cluster.... i got an extra one anyway...
thanks....
Old Jun 16, 2003 | 10:50 AM
crxtreme27's Avatar
Ok... i replaced the cluster and still the same problem.. however today i noticed that speedo cable did not want to stay put even after i raplaced the pin.. i got a light and checked why.. arent we supposed to change that plug thing on the tranny for the D series one??? that might be why the check engine light is still on??
Old Jun 16, 2003 | 11:56 AM
jaydm98's Avatar
maybe that screw is making my vtec not switchover, hmmmm... im gonna go check the cluster, the speedometer works just shakes a little bit... but ill check that screw, im not throwing any codes though, how do you take the cluster off, never took it off, i know there are two screws at the bottom, are there anymore?
Old Jun 16, 2003 | 12:41 PM
dester223's Avatar
What ECU are you running?
Old Jun 16, 2003 | 01:02 PM
jaydm98's Avatar
Default Re: (dester223)
im running a pr3
Old Jun 16, 2003 | 01:03 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Does the VSS affect vtec??? (crxtreme27)
Your speedo is working right? And you weren't getting a VSS code before the swap right? My guess is that you don't have the VSS signal wire to the ECU in the correct spot or the wire running from the cluster to the eCU is messed up some how.
Old Jun 16, 2003 | 01:08 PM
jaydm98's Avatar
Default Re: Does the VSS affect vtec??? (4drEF)
yeah the speedo does work, how do you take the cluster off?
Old Jun 16, 2003 | 01:52 PM
crxtreme27's Avatar
for me.. i dont know if the VSS code was there before the swap because i got the car with the swap... i am running the pr3 ecu but i guess ill try the pw0, i jhave an extra one layin around.. im still thinking that my problem might come from the transmission speedometer cable socket thing...
Old Jun 16, 2003 | 04:57 PM
CimorelliCRX's Avatar
Not to et in the topic, but i am about to run obd1, and i need an electronic VSS right? If I dont have one, then VTEC will not engage, correct? TIA.
Old Jun 16, 2003 | 06:17 PM
keebler65's Avatar
Default Re: Does the VSS affect vtec??? (CimorelliCRX)
ok well since your speedo works, we know it is an electrical problem. do this: unplug your ecu. take an ohm meter or continuity tester and see if there is continuity between the bolt that is pictured above and pin B16 on your ECU harness. if there isnt a complete circuit, then its time to start looking for broken wires, etc. HTH
Old Jun 16, 2003 | 07:25 PM
crxtreme27's Avatar
Default Re: Does the VSS affect vtec??? (keebler65)
Thanks for the info.. that will be my next step... ill keep you guys posted..
Old Apr 28, 2020 | 01:40 PM
Sergio Flores's Avatar
what screw are you talking about?
Old Apr 29, 2020 | 06:40 PM
DaX's Avatar
DaX
Loved
Community Favorite
The screws that hold the speedometer into the cluster. These screws make an electrical contact with the flexible circuit on the back of the cluster. If one of the screws is loose or missing, it may not be making the connection needed for the VSS to work.
DA_JDM
14
May 30, 2007 08:40 AM
7mgtemk3
Feb 21, 2005 05:09 PM
irtep
Sep 1, 2003 02:07 PM
