code 17 vss
code 17 vss
i've got engine code 17 and i was just wondering if it's affecting my vtec? 89 civic, b16, pr3, jdm cluster and eg electronic vss. should i be using a dc electronic vss or is the eg ok? the speedo on the cluster is still working.
No Big Whoop
Re: code 17 vss (irtep)
The EG VSS is fine. you have a problem in the wire that goes from the back of the cluster to the ECU. Begin by making sure this screw is nice and tight at the back of the cluster.
then make sure you have continuity from the cluster to the ECU.
If your speedo works, then the problem is the wire from the cluster to the ECU.
1 Post
Re: code 17 vss (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">Ive heard that with a code 17 vehicle speed sensor that vtec wont kick in</TD></TR></TABLE>
You are correct. If using a VTEC ecu, you need to be above 10mph for activation, and if the ecu does not see the vss then it cant tell that it is going through the speed threshold.
civichatch2307
08-07-2007 07:06 PM
hb_guy
13
05-25-2006 08:23 PM
jdmbaby
09-29-2005 11:03 PM
GdmLaz
16
12-12-2004 03:33 PM
