hesitation
Old Jun 14, 2003 | 09:37 AM
crxchris's Avatar
Default hesitation
ok so while under slight throttle my car will some times hesitate as if its trying to go but cant i was thinking this could be a fuel problem? but not sure also my headers are slightly against my crossmember im ordering a place racing member to aleviate this but didnt think it would cause a prob till it gets here am i correct? tia for the help
Old Jun 14, 2003 | 10:52 AM
Blue_Si03's Avatar
Default Re: hesitation (crxchris)
Try changing your fuel filter.
Old Jun 14, 2003 | 10:55 AM
crxchris's Avatar
thanks thats what i was thinking
Old Jun 14, 2003 | 11:06 AM
Hartlage's Avatar
My B16A1 does the same thing. You might be running too rich. I changed the fuel filter,plugs, wires, ect., and it didn't help. Apparently it is a common problem w/ the B16A1's, not sure about the A2's. It everything else does not work, use a V-AFC and lean it out a little.
Old Jun 14, 2003 | 11:30 AM
Rywire's Avatar
Default Re: (Hartlage)
Its prolly a o2 problem, like you have them switched. Or a bad tps. Ryan
Old Jun 14, 2003 | 11:36 AM
Hartlage's Avatar
does it matter which bung the O2's are plugged into? I didn't know it made a difference.
Old Jun 14, 2003 | 11:39 AM
blah13's Avatar
The common things I hear for this are the O2, timing, spark components,(plugs, wires, rotor etc) and fuel filter/pump. I'd go with cheapest first, make sure your timing is on, check your plugs for any abnormal wear/indications, change your plugs and rotor, fuel filter and O2. I hear a lot on the b16's that its the O2 wiring and on D series its timing/ignition.
My 90dx did the same thing and it turned out that my belt had jumped a tooth and was retarded 16 degrees. Ran strong as hell after 3k rpms...
Old Jun 14, 2003 | 11:44 AM
crxchris's Avatar
w\out a timing light how can i tell doesnt seem to be off, only had b16aII in for a couple weeks can sensors go bad that fast as i replaced tps and o2 will def change filter tonight any advise on how to do so plugs and wires are new as well thanks again for all the help and as hartlage said does the o2s matter which bung
Old Jun 14, 2003 | 12:08 PM
blah13's Avatar
Default Re: (crxchris)
Well without a timing light you cant tell if the ignition timing is off, make sure your cam gears lined up.
Old Jun 14, 2003 | 12:18 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">w\out a timing light how can i tell doesnt seem to be off, only had b16aII in for a couple weeks can sensors go bad that fast as i replaced tps and o2 will def change filter tonight any advise on how to do so plugs and wires are new as well thanks again for all the help and as hartlage said does the o2s matter which bung</TD></TR></TABLE>
Yes, it does matter which o2 is in which spot, you should check them to verify. Do you have a aftermarket header, or is it stock? Ryan
Old Jun 14, 2003 | 12:31 PM
crxchris's Avatar
itr 4-1 w\stock bung
Old Jun 14, 2003 | 12:32 PM
crxchris's Avatar
im pretty sure i need to change the fuel filter how is this done? tia
Old Jun 14, 2003 | 04:22 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">itr 4-1 w\stock bung</TD></TR></TABLE>
Are you running a chip that eliminates the second o2? If not, this may be your problem. Ryan
Old Jun 14, 2003 | 06:20 PM
E-AT_me's Avatar
Default Re: (droppedcrxsi)
dude, mine does the same thing.. it's only sometimes, but then it'll go away.. it's not the O2 sensors.. i have to look at the TPS then.. and possibly timing...
Old Jun 14, 2003 | 08:02 PM
Rob!'s Avatar
Default Re: (Rexman)
im havin the same problem on my b16...i dunno what it can be...its bad tho sometimes i cant even drive it...my tach jumps all over like crazy and the car hesitates like hell....cant figure out what is wrong with it.
Old Jun 14, 2003 | 09:39 PM
incubus's Avatar
Default Re: (b16hf)
I have hesitation sometimes also... didnt we just do this last week? O2 sensors, try switching them.
Old Jun 14, 2003 | 11:09 PM
DrRoboto's Avatar
If you are using a pr3 or pw0, with stock chip, stock fuel pressure, no afc, etc, it's critical that the o2's be close to the stock location and wired correctly (sometimes the primary and secondary may be reversed after a swap) or your daily drivability is going to suck, plain and simple. ITR headers with an o2 down by the collector are not going to give the computer the proper feedback, thus causing the computer to try to lean or richen the mixture the wrong way resulting in hesitation, bogging, sputtering, even stalling sometimes (happened to me at least 5-6 times). If your car runs fine at WOT and also at startup when it's cold, this is probably your problem, at startup and WOT the computer doesn't look at what your o2's are reading.
Old Jun 15, 2003 | 12:06 PM
Hartlage's Avatar
Mine only hesitates at part throttle and when the engine is cold.
Old Jun 15, 2003 | 02:08 PM
DOHCRX's Avatar
try unplgging your 02 sencors and if it works go switch em on your ECU...i had the same problem it worked mint
Old Jun 15, 2003 | 05:45 PM
type Gendy's Avatar
https://honda-tech.com/zerothread?id=513728
Old Jun 15, 2003 | 05:53 PM
E-AT_me's Avatar
Default Re: (sick hatchem)
see, i have it even after i know my O2 sensors are correct...
Old Jun 17, 2003 | 05:33 AM
crxchris's Avatar
i had a fuse that was going and my alternator had a bolt loose which wasnt helping my o2s are right and it still does it occasionally
Old Jun 17, 2003 | 07:36 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hartlage &raquo;</TD></TR><TR><TD CLASS="quote">Mine only hesitates at part throttle and when the engine is cold.</TD></TR></TABLE>
Same problem I'm having It'll run fine when it's dead cold, but when it's in the intermediate zone between fully cold and fully warm it'll hesitate and buck at part throttle. Give it gas and it takes off.
I'm thinking TPS right now... I know my O2s are wired correctly (I've already been through that). Forgot to mention, my O2s are in the stock location (stock B16A manifold).
Old Jun 17, 2003 | 12:39 PM
Hartlage's Avatar
Default Re: (raene)
Yeah, I'm thinking TPS right now. I had the swap done by a shop and I doubt they would switch the 02's. It has always hesitated at part throttle but it recently started having starting problems when cold.
Old Jun 17, 2003 | 01:32 PM
spun Vtec's Avatar
i second tps sensor
