HID Question
I tried a search but couldn't find what I was looking for (stupid 3 letter words like: JDM HID NON) anyway I have the NON-HID JDM Lights, and a set of HIDs....now my problem is no matter what I do they keep pointing down too much, how can I reaim them?? Is there a screw or something i can **** w/ or anything like that???
There are two adjustment gear looking things. the one near the corner lights is the side adjustment and the one behind the low beam is the up down adjustment. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr »</TD></TR><TR><TD CLASS="quote">There are two adjustment gear looking things. the one near the corner lights is the side adjustment and the one behind the low beam is the up down adjustment. good luck</TD></TR></TABLE>
behind? Explain please...I can see the one that is inbetween the lowbeams and the higbeam/city lights, but i can't see another wheel....Also will just playing with these wheels work or will I have to take apart the housing?
What type of HID kit did you put in there?
Did you replace your projector or did you just get a bolton kit?
http://www.autooptiks.com/aiming.html - good aiming instructions.
look above your low beam toward the fender on top of the radiator support. There is a hole in the radiator support. look in that hole and you will see the other adjustment gear. If all you need is up and down, you are already looking at it. It makes slow adjustments but it works. I have the OEM HID, so if your retrofit aims different than I don't think that anyone here can help you.
It's in the same place on the jdm. Look carefully on the grey plastic on top. You should see a raised "L" with an arrow and a raised "R" right behind it is the gear. It really isn't that hard to find.
vestalfootball72
11
May 10, 2006 05:25 AM
