HID Question
Old Jun 14, 2003 | 08:14 AM
MissMyHonda's Avatar
Default HID Question
I tried a search but couldn't find what I was looking for (stupid 3 letter words like: JDM HID NON) anyway I have the NON-HID JDM Lights, and a set of HIDs....now my problem is no matter what I do they keep pointing down too much, how can I reaim them?? Is there a screw or something i can **** w/ or anything like that???
Old Jun 14, 2003 | 09:34 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
yes, just look at your owners manual on adjusting headlights, your lights will adjust the same way.
Old Jun 14, 2003 | 10:06 AM
Default Re: (Rguy)
i did, and I didn't find **** that looked like it does in the USDM headlights....
Old Jun 14, 2003 | 11:37 AM
Anyone???
Old Jun 14, 2003 | 12:02 PM
jdmspoonitr's Avatar
Default Re: (JoesTypeS)
There are two adjustment gear looking things. the one near the corner lights is the side adjustment and the one behind the low beam is the up down adjustment. good luck
Old Jun 14, 2003 | 12:38 PM
Default Re: (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">There are two adjustment gear looking things. the one near the corner lights is the side adjustment and the one behind the low beam is the up down adjustment. good luck</TD></TR></TABLE>
behind? Explain please...I can see the one that is inbetween the lowbeams and the higbeam/city lights, but i can't see another wheel....Also will just playing with these wheels work or will I have to take apart the housing?
Old Jun 14, 2003 | 02:05 PM
skafia's Avatar
25 Year Member
What type of HID kit did you put in there?
Did you replace your projector or did you just get a bolton kit?
http://www.autooptiks.com/aiming.html - good aiming instructions.
Old Jun 14, 2003 | 04:57 PM
Default Re: (skafia)
It's a retrofitted HID system off a 02 maxima my friend had and totalled the car from the rear, so I got free HIDs :thumbsup:...anyway they're in there...any advise?
Old Jun 14, 2003 | 05:22 PM
look above your low beam toward the fender on top of the radiator support. There is a hole in the radiator support. look in that hole and you will see the other adjustment gear. If all you need is up and down, you are already looking at it. It makes slow adjustments but it works. I have the OEM HID, so if your retrofit aims different than I don't think that anyone here can help you.
Old Jun 14, 2003 | 09:21 PM
I mean is the thing to adjust them ON the headlight piece itself or is it supposed to be attached to the bulb? A pic would work awesome if you have one!! Thanks.
Old Jun 15, 2003 | 02:35 AM
nightrider's Avatar
here you go.
counterclockwise=raises beam or inward
Old Jun 15, 2003 | 04:09 PM
That looks like a USDM, I have JDM.....
Old Jun 15, 2003 | 05:48 PM
It's in the same place on the jdm. Look carefully on the grey plastic on top. You should see a raised "L" with an arrow and a raised "R" right behind it is the gear. It really isn't that hard to find.
Old Jun 18, 2003 | 05:45 PM
Wow, I found them, god I'm an idiot...thanks, they now light up A LOT more than just the first 10 feet infront of the car
lif3tak3n
Mar 5, 2007 12:51 AM
radio1global
Feb 20, 2007 01:43 PM
vestalfootball72
11
May 10, 2006 05:25 AM
hondaitegra
Jun 4, 2004 06:34 PM
OneThirtyEight
Jun 22, 2001 07:30 AM
