Just cleaned engine bay....u know what im gonna say next...
...and the car wont stay on. I simp;le greened it, sprayed it down, let it sit, tried to start...no good. Then took off distributer cap, plug wired and blew it with the vacuum cleaner on BLOW ( haha, just felt like i needed to scream that). Put everything back together and car cranks, if i gas it at the right time i can get it to run, VERY badly, if i stop giving it throttle it dies.
SO, everything is now dry but car still sounds like a its 3 spark plugs and 2 pistons
edit: this will be the last time i every clean myt motor
Did you cover you distribotor cap and plug wires while spraying the motor?? I keep the plug wire cover on and put a bag over the ditributor cap, etc., and leave the car running while I spray the motor down. Never had a problem, and I've done this a hundred times.
check your plug wires at the plug end. water may have gotten in there. BLOW that out, too.
what's the condition of your plug wires themselves? last time they were changed?
When I clean my engine I cover the distributor, alternator and battery. You shouldn't spray directly into the head or anything.
? Wait til the morning see if she starts.
i covered the dist. but nothin else...i dont think the bay has EVER been cleaned before i got it not too long ago so i cleaned and sprayed down every NUT and bolt under the hood.
The wires are stock...70k.
Skafia- thanks for the repkly but your link in your sig was more valueble to me
ahhhh, ive done that to my ls, the problem was that water got into the spark plugs, but a R already has a spark plug cover? but anyways if they did end up getting in there, get a towel with a long screwdriver and soak up the towel with the water
pull your plug wires and used compressed air to dry them off inside the boot. Then leave your spark plugs IN and spray compressed air into each cylinder. Now pull your plugs and your fuse for the fuel injectors just as if your were doing a compresiontest and dry crank the motor 9-10 times. After that you have done everything you can to get the water out with out screwing **** up. Don't worry about it man. It happens when you spray down a motor. Noting to stress about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">Now pull your plugs and your fuse for the fuel injectors just as if your were doing a compresiontest and dry crank the motor 9-10 times. After that you have done everything you can to get the water out with out screwing **** up. Don't worry about it man. It happens when you spray down a motor. Noting to stress about. </TD></TR></TABLE>
which fuse panel is the one for the injectors in, and pleeeease dont tell me its the one under the dash b/c my car was sold to me w/out one
just try again in the morning. let the water dry off from where ever it may have gotten.
yeh we all love skafia's **** collection
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2dark2bslow »</TD></TR><TR><TD CLASS="quote">which fuse panel is the one for the injectors in, and pleeeease dont tell me its the one under the dash b/c my car was sold to me w/out one
What?! So you don't have a fuse panel under your dash inside the car? How the hell does this work?
</TD></TR></TABLE>What?! So you don't have a fuse panel under your dash inside the car? How the hell does this work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dels98R »</TD></TR><TR><TD CLASS="quote">ahhhh, ive done that to my ls, the problem was that water got into the spark plugs, but a R already has a spark plug cover? but anyways if they did end up getting in there, get a towel with a long screwdriver and soak up the towel with the water</TD></TR></TABLE>
hahaha
hahaha
HTn00b
43
Nov 8, 2006 02:35 PM
Gamble-Did-it
Sep 17, 2006 12:17 AM
ltho1998
Sep 27, 2003 05:52 AM
