WTF!!!!!!!!! Idle Problem with Skunk 2 manifold..!!!! HELP
Old Jun 13, 2003 | 04:40 PM
user 996328629's Avatar
Default WTF!!!!!!!!! Idle Problem with Skunk 2 manifold..!!!! HELP
ok guys, im running out of patience with my damn manifold...It RUNS perfectly fine, but it idles constant at 1400-1500.......
I got a new (30k miles) Fast idle Sensor..replaced that..than the shop ran a new IAVC valve, and that wasnt it....
Vaccum lines is what im thinking now? I have a 95 GSR, Is there any "t" lines that are appose to go ANYWHERE because i do not have any? If anyone can shed some light, please help!!!
Default Re: WTF!!!!!!!!! Idle Problem with Skunk 2 manifold..!!!! HELP (Swags04)
Also, on the IAVC i do not have a sensor connected...2 of them do nothing and the other 1 shoots my idle to 1000-5000 ..........im so confused.
Old Jun 13, 2003 | 04:48 PM
MooreBoost's Avatar
My only guess would be that you have a vacuum line routed wrong. Generally, when replacing an IM without replacing your TB, you will idle lower than stock. However, you should probably be throwing a CEL if the vac was wrong, does your idle bounce at all? Try recetting you ECU.
gmoore
Old Jun 13, 2003 | 08:18 PM
Default Re: WTF!!!!!!!!! Idle Problem with Skunk 2 manifold..!!!! HELP (tegunderpressure)
Throwing 7,10, and 14......Which is Throttle Position, IACV, and Intake air temp..however, my shop tells me my Fast idle thermo valve was being shitty, and i replaced it, and its still acting up..Someone help!
Old Jun 13, 2003 | 08:28 PM
Jsracingintegra
Guest
Posts: n/a
For code 7 if you yanked on the tps sensor wires too hard you could have damaged it. For everything else there is an air leak somewhere.
Old Jun 14, 2003 | 09:46 AM
Default Re: WTF!!!!!!!!! Idle Problem with Skunk 2 manifold..!!!! HELP (Jsracingintegra)
bump...TPS, is not the problem.
Old Jun 14, 2003 | 10:49 AM
Anyone???????Can someone give me a graph of vaccum lines? Im almost positive mine are right..
integra15
Jun 23, 2010 02:30 PM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
94SHOWLS
Feb 17, 2005 12:31 PM
Spade
Jun 29, 2002 06:32 AM
