question about mixing grades of gas
Old Jun 13, 2003 | 09:50 AM
JeremyL's Avatar
Default question about mixing grades of gas
i can get 110 octane around my area for $3.99 but filling my tank at $3.99 would break the bank...could i use a few gallons of the 110 race gas and the rest 93 octane? would this cause any problems? would i be better off just getting a good octane booster?
Old Jun 13, 2003 | 10:06 AM
btl fed's Avatar
Is there a reason you want race gas? If you only have i/h/e you shouldn't need 110 octane.
Old Jun 13, 2003 | 10:09 AM
JeremyL's Avatar
Default Re: (btl fed)
it would be for the WRX
Old Jun 13, 2003 | 10:56 AM
xteg95's Avatar
Default Re: (JeremyL)
wrx doesnt need 110 octance...its not 800hp or anything. unless you got a drag car just use 93.
Old Jun 13, 2003 | 10:58 AM
cletus's Avatar
putting gas with higher octane than you need will not give you any power or make the car run better......in fact higher octane gasses will not burn completely and the exhaust will be much dirtier........i forget who did the test but a 4 cyl accord was filled, run and dynoed with different octane gas and it actually lost power with the higher octane.....granted that was an accord and this is for the scooby but you should stick with the 93 if it is stock.......under higher boost conditions higher octane will be needed to control detonation
Old Jun 13, 2003 | 10:59 AM
JeremyL's Avatar
Default Re: (xintegra01)
i do plan on upping the boost a bit later on, ishould be pretty set tho at 93 for what id be doing...i would ike to see how it would run on 110 tho
Old Jun 13, 2003 | 11:09 AM
cletus's Avatar
it wont run any different.....
Old Jun 13, 2003 | 11:34 AM
Frito1's Avatar
Default Re: (cletus)
110 way to much. dude that car was built for the street not track. wtf you need 110 octane for. waste your money if you want.
Old Jun 13, 2003 | 11:36 AM
koco's Avatar
Default Re: question about mixing grades of gas (JeremyL)
Can you actually run 110 OCtane with a stock fuel system? Aren't you worried about trashing the seals and O rings?
Old Jun 13, 2003 | 11:45 AM
Br1t1shguy's Avatar
Default Re: question about mixing grades of gas (koco)
It wouldnt run any different. In fact it might run worse, as that high octane may burn incompletely under stock boost.
Old Jun 13, 2003 | 11:52 AM
jeebusm3's Avatar
Default Re: question about mixing grades of gas (Br1t1shguy)
you should be thankful you can get 93!
Old Jun 13, 2003 | 02:27 PM
NeoGSR's Avatar
Default Re: question about mixing grades of gas (gtravsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtravsr &raquo;</TD></TR><TR><TD CLASS="quote">you should be thankful you can get 93!</TD></TR></TABLE>
no kidding, i can only find 91 within 20 miles of my stupid town!!!
Old Jun 13, 2003 | 02:45 PM
Type Wah's Avatar
My LS only drinks 87, 89 when she goes to the track...
hello1320
Sep 21, 2010 05:34 AM
SlowEJ8
48
May 2, 2009 06:44 AM
hometheaterman
Apr 16, 2006 02:02 PM
Muckman
Oct 4, 2003 02:12 AM
Stryker908
15
Aug 15, 2003 09:52 PM
