Will 5spd tranny from any civic work in place of a 4spd
Old Jun 12, 2003 | 10:38 PM
Civmochris's Avatar
Default Will 5spd tranny from any civic work in place of a 4spd
i just wanted to know whether or not a 5spd tranny will work in place of a 4spd. i didnt know if it would just bolt up or whether or not i would have to change things like axles and what not
thanks
Civmochris
Old Jun 13, 2003 | 12:05 AM
Vinceg99's Avatar
Default Re: Will 5spd tranny from any civic work in place of a 4spd (Civmochris)
Yeah it will bolt right up and you can use the same axles as well too.
Old Jun 13, 2003 | 05:00 AM
Home Skillet's Avatar
Default Re: Will 5spd tranny from any civic work in place of a 4spd (Vinceg99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it will bolt right up and you can use the same axles as well too.</TD></TR></TABLE>
You sure about that? I thought the 4spd axles were smaller than the 5spd's. I had to upgrade my brakes when I did my ZC swap.
Old Jun 13, 2003 | 06:10 AM
jlicrx's Avatar
Default Re: Will 5spd tranny from any civic work in place of a 4spd (Home Skillet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">
You sure about that? I thought the 4spd axles were smaller than the 5spd's. I had to upgrade my brakes when I did my ZC swap. </TD></TR></TABLE>4spd axles only smaller where they go into hub - the transmission end is the same on STD, DX and Si - ZC is different at the transmission and uses integra axles which won't fit the STD hubs, but will fit DX and Si
Old Jun 13, 2003 | 08:06 AM
Vinceg99's Avatar
Yeah the outer side is smaller on the 4 spd than the 5 spd (as he said above) but if all he is doing is swapping trannies the hubs will be the same which means he can use the same axles.
Old Jun 13, 2003 | 09:45 AM
ok, thanks, I stand corrected.
Old Jun 13, 2003 | 10:18 AM
RuthlessEF-9's Avatar
it will bolt easily if its not an 88
Old Jun 13, 2003 | 05:10 PM
Vinceg99's Avatar
Default Re: Will 5spd tranny from any civic work in place of a 4spd (D16z6turbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16z6turbs &raquo;</TD></TR><TR><TD CLASS="quote">it will bolt easily if its not an 88 </TD></TR></TABLE>
Why if not an 88? An 88 will bolt right in just like the rest of them but where the troubles comes is with the clutch and flywheel which if he WAS swapping in an 88 trans and got the 88 clutch and flywheel it would be fine.
Old Jun 14, 2003 | 10:58 PM
Civmochris's Avatar
thanks for the help i didnt know if the trannies were the same as everyone knows that the gear ratio sucks on a 4spd once a gain thanks. one more thing goes anyone know what i will need to do mini me swap onto a 91 STD hatch the head is of of a 94 del sol it has both manifolds and all of the sensors thanks
Civmochris
Old Jun 15, 2003 | 07:18 AM
USDM 4G VTEC's Avatar
do a search on mini me and DPFI to MPFI
u gotta convert ur car first to MPFI then u need a vtec head...
JDM_Ej
22
Jul 26, 2005 07:41 AM
onefiine69
Mar 12, 2005 05:08 PM
the niz jiz
11
Jan 29, 2005 03:12 AM
hellogoodbye
Apr 5, 2004 04:11 PM
Mike P.
Aug 21, 2003 01:25 PM
