Guages Install?
Old Jun 12, 2003 | 06:17 PM
1.6sohc's Avatar
Default Guages Install?
Where do i put water temp, oiltemp sending units on my D16A6? Any ideas?
Old Jun 12, 2003 | 06:36 PM
durangedesign.com's Avatar
Default Re: Guages Install? (1.6sohc)
I know if it is a manual aftermarket gauge then the oil pressure sending unit is right under the head on the back of the block, it has a fitting, you can take a fitting from the kit and adapt it on there, as for the water temperature I have no idea where this will work at, the prong on the aftermarket ones are a tad long to go anywhere, you can put it in your radiator drail plug but that is not an acurate reading.
MugenPoweredLude
Jun 10, 2004 07:48 AM
Phoenix_ITR
Jan 8, 2004 12:35 AM
Integra Xsi
Jan 4, 2004 06:15 PM
S@nt0s
Dec 1, 2003 03:23 PM
HapaHaole
Jan 31, 2002 10:43 AM
