crank main seal replace qs??
Old Jun 12, 2003 | 02:25 PM
JCracer723's Avatar
Default crank main seal replace qs??
im about to replace the crank main seal on my b16z6.(i know this might belong to the eg forum but Ive already tried and no luck.. and i think they are the same as A6).
here is my question. do i remove it with out taking the seal holder out? or do i have to take it off?? tia.
Old Jun 12, 2003 | 04:42 PM
sporkcrx's Avatar
Default Re: crank main seal replace qs?? (JCracer723)
The rear main seal or the seal at the front of the engine? I did my rear main w/out removing anything but the clutch assembly. The front seal will be a bitch.
Old Jun 12, 2003 | 05:26 PM
JCracer723's Avatar
Default Re: crank main seal replace qs?? (sporkcrx)
wuts a front and rear seal?? the main crank seal im talking about its the 1 at the flywheel side. on the other side it would be the oil pump seal
Old Jun 12, 2003 | 06:17 PM
primoEF's Avatar
thats call the rear main seal
Old Jun 12, 2003 | 06:41 PM
JCracer723's Avatar
Default Re: crank main seal replace qs?? (primoEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primoEF &raquo;</TD></TR><TR><TD CLASS="quote">thats call the rear main seal</TD></TR></TABLE>
Old Jun 13, 2003 | 09:57 AM
JCracer723's Avatar
any1 else?
Old Jun 13, 2003 | 10:05 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do i remove it with out taking the seal holder out? or do i have to take it off?? tia.
What do you mean, whats a seal holder ? Any ways maybe this will help.
Use a tiny screw driver to pry out the old seal, be careful though not to chip the block. And getting it back in can be a bit harder because you put one side in and the other pops out, here is a little trick, rest the seal on the spot its suppose to go back in to , then put the flywheel on and tighten the fly wheel. This will push it in evenly.
Old Jun 13, 2003 | 10:42 AM
JCracer723's Avatar
Default Re: crank main seal replace qs?? (90blackcrx)
this is the cover/holder im talkin about
Old Jun 13, 2003 | 10:45 AM
Ef Whore's Avatar
Make you get it to sit totally flat, and be gentle putting it in.
Old Jun 13, 2003 | 11:22 AM
sporkcrx's Avatar
Default Re: crank main seal replace qs?? (Ef *****)
No, you don't need to take off that cover. Just take off the flywheel, then yank the **** out. Pop the new one back in. Good $5 insurance.
Old Jun 13, 2003 | 11:31 AM
JCracer723's Avatar
thnkx
Old Jun 13, 2003 | 11:35 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Use a tiny screw driver to pry out the old seal, be careful though not to chip the block. And getting it back in can be a bit harder because you put one side in and the other pops out, here is a little trick, rest the seal on the spot its suppose to go back in to , then put the flywheel on and tighten the fly wheel. This will push it in evenly.</TD></TR></TABLE>
OMG that is a WICKED trick! Thank you so much for posting that! I spent like 2 hours trying to tap that thing in evenly with a wooden mallet
Old Jun 13, 2003 | 12:14 PM
Default Re: crank main seal replace qs?? (raene)
Glad I could be of some help, I also spent about 2 hours trying to get it to go in. I was trying to find things to use as a driver and I did not have a socket big enough to act like one, I tryed just about everything. And it was late and no stores were open so I tryed using the flywheel as a socket driver and it worked. Neat little trick.
mattbatson
May 4, 2012 04:26 AM
hondaapi
Jan 7, 2008 09:20 AM
elmo908
Apr 15, 2007 04:35 PM
91crxturbo
Sep 1, 2006 09:38 PM
GSRwBOOST
Jul 7, 2001 09:15 PM
