Solid motor mounts....who makes em? who has em?>
Old Jun 12, 2003 | 11:21 AM
gocivicgo's Avatar
Default Solid motor mounts....who makes em? who has em?>
Anyoen herer using solid motor mounts? Im nto even sure if you can getthem for a honda, maybe custom fabricated? I know they really helped in my 68 camaro, would they help in a honda as well??
Any opinions or comments
THANKS
Old Jun 12, 2003 | 11:42 AM
EL Vap133's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (gocivicgo)
If you like heavy vibrations, try Madd Engineering. Have you considered Urethane inserts?
Old Jun 12, 2003 | 12:35 PM
gocivicgo's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (Vap133)
Well i was thinking about making my own mounts totally solid.....i dont have nay at all right now. I Dont mind the vibrations , they were really bad in my 68 camaro. Does Madd Engineering have a web site?
Old Jun 12, 2003 | 12:37 PM
Urban Business
Guest
Posts: n/a
you dont want solid mounts. use poly inserts. engine isnt suposed to be locked in place anyway
Old Jun 12, 2003 | 12:51 PM
crxste's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (Urban Business)
If you're suffering from lack of cash, try filling the mounts with Heavy weight buliders caulk, it's like a silicon sealant stuff that you can get from hardware stores.
It'll make you mounts alot stiffer and it's a damm site cheaper than inserts.
Old Jun 12, 2003 | 12:55 PM
Urban Business
Guest
Posts: n/a
Default Re: Solid motor mounts....who makes em? who has em?> (crxste)
inserts are 11 bux
Old Jun 12, 2003 | 01:15 PM
Loaded Butane's Avatar
I have the Energy Suspension mount inserts and they work pretty well.
Old Jun 12, 2003 | 01:17 PM
gocivicgo's Avatar
its not a lack of cash, its not a want of vibrations, I dont even have b series mounts. But im no stranger to fabrication, and i figured that solid mounts help North American cars, thjey improve shifting and decrease power loss. And mayeb they woulds help imports. An d i know i can fab solid mounts.
Old Jun 12, 2003 | 02:12 PM
Malgerus's Avatar
Look, you don't want solid mounts. You want Polyurethane mounts. Engine/transmission mounts are supposed to flex a bit, to prevent parts breakage. Think about it, if there is enough pressure that a polyurethane mount will move, wouldn't you rather have that pressure on the mount that on a stress point somewhere else?
Old Jun 12, 2003 | 06:42 PM
gocivicgo's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (Mr. S)
yes i understand that , but its the same thing with say a chev camaro, other parts will break when you use solid mounts, but you apply more power to the drivetrain rather than losing it through the mounts.
Old Jun 12, 2003 | 07:29 PM
NINJASPY's Avatar
anyone know the part number for poly. mounts for b16 in ef9? what companies make them?
Old Jun 12, 2003 | 10:40 PM
b18crx's Avatar
the more solid the mounts, the more vibration you will feel inside and outside the car. the mounts are not solid for a reason---to absorb vibration. get solid mounts and the whole car shakes. try to find liquid filled.
solid mounts are for engines with much more horses.
Old Jun 13, 2003 | 04:49 AM
white99gsr's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (b18crx)
here you go:
http://cgi.ebay.com/ebaymotors...95244
Old Jun 13, 2003 | 07:37 AM
Wes V's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (white99gsr)
The quickest and easiest thing would be to buy the Hasport or Place Racing mounts, grind out the eurathane bushing section, and then make up round "collars" or "adapters" to take up the space.
If doing the Hasport mounts, the adapter would be aluminum.
If doing the Place Racing mounts, the adapter would be steel.
You should plan on tack welding the adapter to the mount once done to prevent any movement.
By doing this, you prevent having to figure out the correct position of the engine in the car. It's already been figured out by Hasport or Place.
Of course, you sure don't have a guarantee on the mounts any more!!!
Now that I've answered your question, I have to recommend against it for all the reasons listed above!!!!!!!!! In addition to the Honda that I own, I also have a 64 Chevelle, (I'm an Administrator at "camaros.net" & "chevelles.com") so I know where you are coming from.
Wes Vann
Old Jun 13, 2003 | 07:43 AM
Mr Furball's Avatar
check out this thread
https://honda-tech.com/zerothread?id=445236
5 dollars and solid mounts.
Old Jun 13, 2003 | 07:48 AM
gocivicgo's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (Wes V)
Thank you wes , at least i know there is someone out there with a north american muscle car that knows what im talking about, when it coems to solid mounts..
Old Jun 13, 2003 | 10:59 AM
martini's Avatar
Default Re: Solid motor mounts....who makes em? who has em?> (FURBALL B-16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FURBALL B-16 &raquo;</TD></TR><TR><TD CLASS="quote">check out this thread
5 dollars and solid mounts. </TD></TR></TABLE>
poly mounts != solid
Old Jun 13, 2003 | 02:40 PM
SiZ's Avatar
SiZ
How much power could you possibly be losing through your motor mounts?!
alx_90ef
20
May 30, 2014 06:31 AM
exhale
Sep 7, 2007 05:30 PM
white_db8
May 26, 2007 09:34 AM
Rod.
Jul 2, 2005 11:49 PM
00000xxx
Oct 15, 2004 10:50 PM
