Battery Light = Replace Alternator :(
Car:
98 ITR
37k miles
4 months out of warranty
I am having a problem where my battery light comes on intermittingly. I had the car hooked up to a volt and amp meter to test things, and everything was looking good. I would get up to 95 amps of output from the alternator. Then, the battery light came on, and the alternator puts out nothing all of a sudden. In talking with several people, it appears the internal regulator in the alternator is bad.
I am pretty surprised though that this is the case, I expected the alternator to last for several more years.
It looks like I am going to get a new alternator. Besides replacing the belts while I am at it, should I replace anything else? How do you get the alternator out, remove the battery and do that way?
Thanks.
98 ITR
37k miles
I am pretty surprised though that this is the case, I expected the alternator to last for several more years.It looks like I am going to get a new alternator. Besides replacing the belts while I am at it, should I replace anything else? How do you get the alternator out, remove the battery and do that way?
Thanks.
Wes, I have a helms.
If you need copies of some of the pages let me know.
Or if you want, I can come by this Saturday morning, or any saturday for that matter.
Just PM me or Email me, I check H-T during the work week a few times a day as my job is pretty boring sometimes.
Modified by EbboyPSi at 12:11 PM 6/12/2003
Disconnect the battery, unplug and unbolt the alternator, remove the lowerball joint nut and axle nut on the driverside, hit your lower control arm with a hammer or use a ball joint separator to make it loose, remove the 3 bolt to the intermediate drive shaft, then you can either remove the oil filter or the lower alternator bracket to get the alternator off.
Good luck.
Good luck.
Wow, I hope there's a way to remove the alternator without disconnecting the lower ball joint. If you mess with that, you'll need an alignment on top of everything else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell »</TD></TR><TR><TD CLASS="quote">Wow, I hope there's a way to remove the alternator without disconnecting the lower ball joint. If you mess with that, you'll need an alignment on top of everything else.</TD></TR></TABLE>
yeah, sure you do.
yeah, sure you do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">yeah, sure you do. </TD></TR></TABLE>
You need one every time you switch wheels and tires too, I believe.
lol! Heck, I'll get an alignment done if a stiff breeze hits my car.
to abusing my Firestone lifetime alignment privileges.
meterus
Feb 10, 2011 03:00 AM
89edcivic
Sep 26, 2009 02:38 PM
