Power estimate on my JDM ITR engine
Old Jun 11, 2003 | 09:41 PM
Chubz's Avatar
Default Power estimate on my JDM ITR engine
I have a 97 JDM ITR engine (perfect 270 psi in every cylinder) DC JDM 4-1 header, AEM CAI, Skunk2/RSR N-1 Exhaust, 2.5 in high flow cat. Im guessing maybe 175whp/125tq. It will be tuned with my hondata s200
Old Jun 11, 2003 | 09:56 PM
baonest1's Avatar
Default Re: Power estimate on my JDM ITR engine (DeadWrong)
only the dyno can tell
Old Jun 11, 2003 | 10:13 PM
ablangc's Avatar
i put 180whp and 126lbs on a 00 itr engine
Old Jun 11, 2003 | 10:16 PM
Chubz's Avatar
Default Re: (ablangc)
was that with bolt ons
Old Jun 12, 2003 | 05:27 AM
BABY NSX's Avatar
Default Re: (DeadWrong)
Well I hit 178+ with just bolt-ons and no tuning on a USDM (lower compression) engine so I guess that you should pull atleast mid 180s with your engine once tuned.
Old Jun 12, 2003 | 07:58 AM
Chubz's Avatar
Default Re:
thanx for your reply, Im so tempted to swap the cams out but, im leaving the internals alone. I just had a b18c1 block with CTR pistons, full ported and polished head with JUN III and a Sgt JUn III map and I out out 213/139. I sold the engine because my new job requires me to drive 80 miles a day, all stop and go driving, so instead of running that motor into the ground, i sold it to someone who had better use for it.
Old Jun 12, 2003 | 02:38 PM
ablangc's Avatar
that is just with I/H/E. Not bad with 91 octane pump gas
Old Jun 12, 2003 | 03:18 PM
MissMyHonda's Avatar
with I/H/E and VAFC I hit 185 whp w/ my JDM ITR motor and I was pushing 240 across all 4
Old Jun 12, 2003 | 05:47 PM
mafay2's Avatar
New User
depend on which dyno you goto, I would guess between 170-185whp
Old Jun 12, 2003 | 06:42 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadWrong &raquo;</TD></TR><TR><TD CLASS="quote">(perfect 270 psi in every cylinder) </TD></TR></TABLE>
270psi? damn, that's a lot of pressure for a stock motor, no?
Old Jun 12, 2003 | 07:22 PM
BABY NSX's Avatar
Default Re: Power estimate on my JDM ITR engine (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">
270psi? damn, that's a lot of pressure for a stock motor, no?</TD></TR></TABLE>
JDM = higher compression. My USDM motor spits out ~237psi. I would expect a JDM motor to be 20-30psi more.
Old Jun 12, 2003 | 07:37 PM
chad's Avatar
Moderator
man i bet you hit 229 and 169 to the wheels YO
Old Jun 12, 2003 | 08:00 PM
Chubz's Avatar
Default Re: Power estimate on my JDM ITR engine (chad)
perhaps
Old Jun 12, 2003 | 08:18 PM
GettaluvR's Avatar
New User
Default re: (baby nsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX &raquo;</TD></TR><TR><TD CLASS="quote">Well I hit 178+ with just bolt-ons and no tuning on a USDM (lower compression) engine so I guess that you should pull atleast mid 180s with your engine once tuned.
what's ur bolts on
Old Jun 12, 2003 | 08:47 PM
d0nkeyxPunch's Avatar
Banned
Default Re: (GettaluvR)
270 psi? Damn dats pretty good. My JDM '00 ITR motor was 210 psi straight across.
Old Jun 13, 2003 | 03:02 AM
R you serious's Avatar
Default Re: (EM1b18cR)
he'obviously lying..,japnese 97 spec itrs do not lay down 270 compression
Old Jun 13, 2003 | 05:45 AM
BABY NSX's Avatar
Default Re: (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">he'obviously lying..,japnese 97 spec itrs do not lay down 270 compression</TD></TR></TABLE>
Compression numbers vary alot depending on what tool your using. This is why absolute numbers are not that important, what maters is that the numbers don't very across all four cylinders.
FYI: My bolt-ons
- Mugen intake
- Spoon header
- Dynomax Hi-flow cat
- Modified USDM Mugen twinloop (elimintated bottle neck between resonator and cat)
- Comptech fly wheel
Old Jun 13, 2003 | 06:31 AM
delacampos's Avatar
my 97 jdm itr motor shows 240 across the board.
Old Jun 13, 2003 | 07:02 AM
Chubz's Avatar
Should I send you my compression tester, i bet if i used a different one it could be lower. BTW is Japanese, not Japnese, and why would a 97 spec differ from the rest. They are all rated at 11:1 compression. I just posted what I got on my compression tester that all. **** when I had a 12:1 JUN III setup with fully ported and polished head, I was breaking compresion testers, over 300psi in every cylinder.
Old Jun 13, 2003 | 10:37 AM
00MRSi's Avatar
Umm.. Ok.. Why would he lie? Obviously compression testers vary, but I don't see any reason for him to pull these #s outta his ***.
Nice #s..
turbohf
Northwest (Sales)
Aug 2, 2007 11:06 AM
turbohf
Jul 29, 2007 08:36 PM
builthatch
Apr 16, 2007 09:59 AM
ken-shin
Mar 16, 2004 01:19 AM
Chubz
Jun 14, 2003 07:55 AM
