b16 Second Gen....1/4 time..Got better........
Old Jun 11, 2003 | 08:39 PM
ATS*VEEE's Avatar
Default b16 Second Gen....1/4 time..Got better........
sup yall.......ran my car after the dissapointing times last time i posted.......i ran again today and hit 15.598......best out of three runs.........i stll want to know why my trap speed is so low though? i am only at 84-86mph at the most when im done for the quarter mile.....things since last post before the track........i changed both o2's, cap rotor, pcv valve.......plugs and wires i did before.......what else can it be fellahz about my trap speed?!?!?! i should be around 90mph +........thanx
Old Jun 11, 2003 | 08:40 PM
ZC88CRX's Avatar
Default Re: b16 Second Gen....1/4 time..Got better........ (richierich)
what did you run last time?
Old Jun 11, 2003 | 08:57 PM
ATS*VEEE's Avatar
16.8-16.7-16.5-16.2
Old Jun 11, 2003 | 08:59 PM
bossman032's Avatar
Default Re: (richierich)
did you get ur car dynoed yet..?
Old Jun 11, 2003 | 09:04 PM
SEA Hag's Avatar
Default Re: (bossman032)
At least try a compression test before you throw more parts at an unknown problem. Clogged cats can also really hurt performance.
Old Jun 11, 2003 | 09:09 PM
ATS*VEEE's Avatar
nope no dyno yet, i already did a compression test..190 all across.........cat is still stock 89 si hb 1 1/14 in cat i got 2 1/4 in piping
Old Jun 11, 2003 | 09:26 PM
pokemon's Avatar
Wow that is rough, I recently ran my friends EG this past Sunday he has a 1st gen b16 with full interior, with just i/e and he is running a gsr p72 ecu and I hit a 15.03 on 13 bald steelies with a 60' of 2.2 and a trap speed of 90.xx, how is your traction and ****, good tires will help A LOT ,my first run in his car was a 15.8 ( bad traction ), next was a 15.5 ( lil better ), then the 15.0. With some good tires I am sure I could bang a 14.8, on the 15.0 run my reaction time was a .894 which is horrible
Old Jun 11, 2003 | 09:30 PM
ZC88CRX's Avatar
Default Re: (pokemon)
reaction time doesnt make any difference on your et
Old Jun 11, 2003 | 09:32 PM
4door_gsr_ftw's Avatar
An inch difference is a big diference. Try going with a high-flow cat. That might help a little.
Old Jun 11, 2003 | 09:34 PM
keebler65's Avatar
Default Re: (Pacman88)
adjust your timing to stock (it may be off)
Old Jun 12, 2003 | 05:13 AM
REDBARON's Avatar
Default Re: (keebler65)
Last time I went to the track I hit a 15.5 too. Except my mph was 90.67. Are you sure that cat is not clogged?
Old Jun 12, 2003 | 05:23 AM
USDM 4G VTEC's Avatar
post ahead the whole numbers on the best timeslip
that way we can tell if u loosing low end power, top end, u missing a gear, or what
its hard to predict whats wrong with ur car by just a ET .....
i have seen a lot of fast cars runnnig slow.. and its drivers fault....
like RSX T-S runing 16, as a CRX B16 and a CRX ZC... and a 00SI on 15.7's///
so just post the timeslip and we can predict where ur loosing power and give u better answer..... IMO dont really take our guessing opinion.... take it to someone that can really look in ur car and knows.... that might give u better answers
Old Jun 12, 2003 | 07:18 PM
ATS*VEEE's Avatar
r/t .613
60ft 2.401
330ft 6.459
1/8ft 9.954
mph 69.71
1000 12.990
1/4 15.598
mph 85.98
Old Jun 12, 2003 | 07:20 PM
ATS*VEEE's Avatar
there it is fellahz........seriously considering b18c1 soon.....very soon
Old Jun 12, 2003 | 07:38 PM
Blaze45's Avatar
Brrraaaap!
Are you sure that your timming isnt off? Some guy had his off by one tooth and he was running 15.8s. This is a rumor, but maybe you have the auto cams?
Blaze
Old Jun 12, 2003 | 07:40 PM
slooogsr's Avatar
something is pretty strange with that timeslip........
here is my best time so far:
r/t .317
60ft - 2.49
330ft- 6.5
1/8 - 9.953
mph- 73.32
1000 12.82
1/4- 15.2 @ 93
Old Jun 12, 2003 | 07:41 PM
slooogsr's Avatar
compare that with his............
seems like his gearing is a lil weird......... what trans are you using??? maybe he is shifting way tooo late and not getting any more pull out of his setup.......... try shifting a lil sooner
Old Jun 12, 2003 | 07:43 PM
ATS*VEEE's Avatar
y1 tranny.......hasport shift linkage.......3rd gear slight grind.......
Old Jun 13, 2003 | 10:49 AM
ATS*VEEE's Avatar
car runs clean.....no bog.....no nothing........but i kno it could be runnin better.........idles fine runs fine.......new o2, plugs wires cap rotor....pcv.....the thing that i want to kno is that.....why does it rev up slow from 1-5rpm........the rpm's should jump up quicker.......
Old Jun 13, 2003 | 11:03 AM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richierich &raquo;</TD></TR><TR><TD CLASS="quote">the thing that i want to kno is that.....why does it rev up slow from 1-5rpm........the rpm's should jump up quicker.......</TD></TR></TABLE>
lack of torque
civicgsr19
Nov 2, 2004 06:34 PM
max723
Jul 28, 2004 05:59 PM
itsJDMyo
Jun 30, 2004 08:18 AM
ATS*VEEE
38
Aug 19, 2003 11:47 AM
RCautoworks
Dec 12, 2002 01:54 PM
