removing cat heatshield
Old Jun 11, 2003 | 08:22 PM
SOHC_MShue's Avatar
Default removing cat heatshield
should i remove this? Lately my exhaust has been rattling against it like a bitch. It is annoying me so bad now. Could anything negative happen if i take it off?
Old Jun 11, 2003 | 08:33 PM
-1TSXer-'s Avatar
Default Re: removing cat heatshield (SOHC_MShue)
nah, it won't hurt anything but you will feel a bit more heat coming up through the floorboard around the hump area. Mine is removed now and I also removed the one on my old cat.
Old Jun 11, 2003 | 08:35 PM
SOHC_MShue's Avatar
Default Re: removing cat heatshield (-CivicTuner-)
good. I think i'll get rid of that **** tomorrow. The damn rattling is driving me insane. It makes it sound like my car is cheap and falling appart or something whenever i'm sitting at idle.
Old Jun 11, 2003 | 09:02 PM
boostsohfast's Avatar
i'm not running any heat shields at all and i didn't notice any difference.
Old Jun 13, 2003 | 10:43 PM
SOHC_MShue's Avatar
Default Re: removing cat heatshield (boostsohfast)
damn i couldn't get to a certain bolt because my cat is in the way. Did you guys have to remove your cat to get to the heat shield? Also do you have any diagrams or pics of exactly what i need to remove. Is it the metal thing right above the cat? There seem to be other heat shields further back too. Should i remove those? I am assuming my exhaust rattling is because of it hitting the heatshields...i need to know soon..the sounds are driving me insane
Old Jun 14, 2003 | 12:31 AM
mugen76's Avatar
i cut mine off my catco even before i installed it. if the heat bothers you, get some thermal wrap and tighten it down with O-rings.
Old Jun 14, 2003 | 07:01 AM
Carlo's Avatar
Default Re: removing cat heatshield (mugen76)
I'm about to cut mine off too
Old Jun 14, 2003 | 07:17 AM
Sketch_hs's Avatar
i took mine off when I did my exhaust and didn't notice any more heat coming up or anything.
Old Jun 14, 2003 | 07:49 AM
coupedup's Avatar
Default Re: (Sketch_hs)
Just watch it when parking in grass!
Old Jun 14, 2003 | 09:23 AM
SOHC_MShue's Avatar
Default Re: (coupedup)
so i would have to have the cat removed in order to get to it?
speedyracer_25
May 31, 2004 05:00 PM
Stellar1
Feb 19, 2003 05:24 PM
basmasta7
Nov 12, 2002 07:14 PM
B16CRX
Nov 12, 2002 05:52 PM
xXreaperXx
Jan 16, 2002 12:46 PM
