Vtec activation
Old Jun 11, 2003 | 07:29 PM
B18cteg's Avatar
Default Vtec activation
Why does the vtec go on so late in the rpms, instead of midrange rpm my redline start at 7000, and goes on at about 5700. D16y8. also is it bad to run your car that high in the rpms semi-often. Thanks for any help
Old Jun 11, 2003 | 07:50 PM
DJ_SaNdOz's Avatar
Default Re: Vtec activation (d16y8vtec)
vtec switches cam profiles at the optimum point of crossover for the cam's profiles. i.e. the lower rpm's run on one profile of the cam & when that profile is about to stop making good power vtec switches to the high rpm profile to continue the build of power. by lowering vtec engagement on a stock cam you will probably run a little slower. you shouldn't worry about it unless you get an aftermarket cam. hth
Old Jun 11, 2003 | 07:52 PM
bossman032's Avatar
Default Re: Vtec activation (DJ_SaNdOz)
my vtec kicks in around 6000RPM or higher. I am thinking because my ECU or something is messed up maybe my Coolent Temp Sensor but never the less it helps me save gas
Old Jun 11, 2003 | 08:08 PM
CRXRageD's Avatar
sounds like your vtec is engaging just a little late. If an engine is meant to be redlined, I would have to say hi rpm is alright, as long as your aren't bouncing off the rev limiter. Reason why it could be bad cuz your valves can float and pistons can essentially slap those valves and break stuff.
Old Jun 11, 2003 | 08:10 PM
bossman032's Avatar
Default Re: Vtec activation (CRXRageD)
I don't know but I know my car is running good my DYNO can back it UP
Old Jun 12, 2003 | 07:01 PM
B18cteg's Avatar
A SOHC can have 2 different profiles?? and what would be a safe number to run my tach??
Snowman3645
12
Dec 10, 2013 04:13 PM
bp944
Feb 1, 2013 10:52 AM
b16a27
Oct 16, 2004 01:59 PM
Hello-Vtec-Goodbye
Apr 11, 2004 04:41 PM
shauniewalnuts
25
Oct 23, 2003 05:22 PM
