i need help regarding offsets on wheels!!!!!
Old Jun 11, 2003 | 01:43 PM
chinkiechunkie's Avatar
Default i need help regarding offsets on wheels!!!!!
i dont know where to post this but its about my integra so there it is. i going to purchase some wheels 15x7 with a 38+ offset. am i going to have rubbing issues? will it stick out too much? i heard that rota rims come in 38 offsets and they look fine. please help!!!! thanks guys. stanley.
Old Jun 11, 2003 | 02:24 PM
PhatboyNYC's Avatar
Default Re: i need help regarding offsets on wheels!!!!! (*****iechunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****iechunkie &raquo;</TD></TR><TR><TD CLASS="quote">i dont know where to post this but its about my integra so there it is. i going to purchase some wheels 15x7 with a 38+ offset. am i going to have rubbing issues? will it stick out too much? i heard that rota rims come in 38 offsets and they look fine. please help!!!! thanks guys. stanley.</TD></TR></TABLE>
Stock GSR/SI wheels have a +45 offset. A +38 offset will set the wheel further in closer to the car rather than further out. Most people use buy Rotas, get them with a +40 offset which shouldn't cause any rubbing. Depending on your drop, you might have rubbing issues (when turning), with a +38 offset. Hope this helps.
Old Jun 11, 2003 | 03:52 PM
Default Re: i need help regarding offsets on wheels!!!!! (PhAtBoY Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhAtBoY Si &raquo;</TD></TR><TR><TD CLASS="quote">
Stock GSR/SI wheels have a +45 offset. A +38 offset will set the wheel further in closer to the car rather than further out. Most people use buy Rotas, get them with a +40 offset which shouldn't cause any rubbing. Depending on your drop, you might have rubbing issues (when turning), with a +38 offset. Hope this helps. </TD></TR></TABLE>
i thought it'll stick out more??..............anyone else?
Old Jun 11, 2003 | 04:39 PM
mr.beeks's Avatar
38mm is fine for size 15 rims
they are just perfect... no problems sticking out
just use tires
195/50 r15
it will look pretty
Old Jun 11, 2003 | 05:16 PM
The Poopsmith's Avatar
Default Re: i need help regarding offsets on wheels!!!!! (N T R Z R)
i have +35 on 16x7 SSR's and its terrible for a big drop, i get rubbing in the front and back, so much that i had to raise up my car
I think rolling the fenders would help tho.
Old Jun 11, 2003 | 05:26 PM
tilt's Avatar
yep it will stick out more.
I've done some research and basically +40-42 offset is perfect for 7" wide rims. People run in that offset range that run the rather wide 215/45/16 azenis. Not too far in and not too far out. +38-45 should be good for the more popular 205/50/15 or 205/45/16 profile tires though.
http://toy4two.home.mindspring.com/offset.html
i thought it'll stick out more??..............anyone else?</TD></TR></TABLE>
Old Jun 11, 2003 | 05:35 PM
Default Re: i need help regarding offsets on wheels!!!!! (tilt)
thanks guys. i just dont want to roll any fenders. anybody have pictures of dc2s with wheels that have a 38+ offset. thanks again
Old Jun 11, 2003 | 07:40 PM
anyone else??
Old Jun 13, 2003 | 02:40 PM
Boofster's Avatar
I don't know the stock offset but +38 is farther out (away from car) than +40. I had some +40 17" and they rubbed so much I had to take them back and get some +42's. Tucked in OK right now. I'd say +45 would be perfect but +42 is fine.
This is for lowered cars only. As a reference, I had my GC's dropped all the way down...probably a 2.5"~3" drop just for fun the first day I got them with stock wheels and had no rubbing issues whatsoever. I was amazed where the wheel went in that small space under there
Old Jun 19, 2003 | 10:59 PM
mister 5's Avatar
honda's and acura's fit a +38 to +45 offset. +38 are fine
Old Jun 19, 2003 | 11:01 PM
mickey513's Avatar
best to stick with 40mm to 45mm
I have seen people with a offset of 38mm have rubbing problem.
Dipsett
Nov 4, 2012 09:54 AM
smoked08
Dec 19, 2011 07:34 PM
Acura_DreamiN
Aug 24, 2010 11:12 AM
luckyfish1
Mar 25, 2006 05:28 AM
CRITTERMATT
Apr 24, 2003 02:37 PM
