Those with EX cluster....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecracer »</TD></TR><TR><TD CLASS="quote">so far I haven't had any problems. Everything seem to work fine and the rpm and speedometer seem to work like it should. </TD></TR></TABLE>
same here,...i just got rid of my EX cluster and put in an SI cluster,..that works fine also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witty »</TD></TR><TR><TD CLASS="quote">Have you had any problems with the tach being inacurate? I have heard this can be a problem.</TD></TR></TABLE>
I think mine is off a tad from the factory. I can rev it up to around 7,400 indicated, but I heard the rev-limiter is actually like 7,200 I believe.
I have an EX cluster and the tachomter and speedometer is definatly way off. Although Im pretty postive its because I have an h22 under the hood. Im trying to remember if the cluster was accurate with my d16, but im not positive.
my tach seems to be off by a little bit, compared to my autometer tach. however, i don't even know if that's accurate, i connected it at the dizzy, so it may be more accurate than my cluster. they both read diff. about 2-300 rpms at redline.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">I haven't had any problems with my tach.
But my temp gauge stays in the red...
Me too! I took it out and put my old cluster back in
</TD></TR></TABLE>Me too! I took it out and put my old cluster back in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">my tach is off by 200rpms...how do i know this? because my s-afc says so. </TD></TR></TABLE>
according to my VAFC, my stock tach is off by 500 RPMs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel »</TD></TR><TR><TD CLASS="quote">
my guage cluster tach (gsr cluster and dash) with a GSR motor in my civic is off also according to my VAFC...
</TD></TR></TABLE>my guage cluster tach (gsr cluster and dash) with a GSR motor in my civic is off also according to my VAFC...
checked mine EX cluster that i got for my cx like an year ago at the local yard and seems my rpms are off about 100-120 RPM thats ok though got a shift lite so i hardly look at the tach..
Mine seems to be doing fine. Only had it in for a short while tho. We'll see. I didn't think that having a diff engine from the cluster itself would throw things off. Hmm. I done got learned.
best thing to find out if the tach is off, is dyno use the dyno exam's that'll tell u the truth from the RPMs where it cuts off at high rev or the V-AFC controller and compare it with the needle to the exam's or the v-afc
yup. same here. conversion from digital to analog will always cause inaccuracy. tach in the cluster is a must, but if you need to be accurate best get a VAFC or a rev/speed meter.
importboi22
Nov 30, 2003 03:40 AM
