4G coolant flow questions
Old Jun 11, 2003 | 11:53 AM
kb58's Avatar
Banned
Default 4G coolant flow questions
I'm confused about the thermostat. The temperature sensing side of the thermostat is facing the water pump inlet, true? How then can the thermostat know when to open if the water feeding it (returning from the radiator) only heats the side *away* from the actual sensing element of the thermostat.
Also, have any of you blocked off your heater lines? Did you plug them or just connect the lines together?
shm91
14
Oct 2, 2013 05:05 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
Quik89Si
Jan 3, 2005 07:06 PM
dkdjlf
Aug 14, 2003 10:34 AM
96_GSR
Jun 27, 2002 08:19 AM
