after gsr gauge install no vtec???
Old Jun 11, 2003 | 10:33 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default after gsr gauge install no vtec???
well i got my gsr cluster in and installed and i have no vtec, i know its only a sohc, but shouldnt i hear vtec atleast a lil bit?? the temp gauge works, and so doesnt the speedo so i dont understand why my vtec wont work?
Old Jun 11, 2003 | 03:10 PM
cspciviclx's Avatar
Default Re: after gsr gauge install no vtec??? (coptzer)
ttt for a buddy and i want to know too kinda bogles my mind ...
Old Jun 11, 2003 | 04:32 PM
rob d's Avatar
What motor? You cant really hear sohc vtec
Old Jun 11, 2003 | 04:46 PM
pdiggitydogg's Avatar
^na...I have y8 and I hear my vtec every time
Old Jun 11, 2003 | 05:55 PM
cspciviclx's Avatar
Default Re: (pdiggitydogg)
he has a 93 si with the z6 motor he says it hits a wall at 6 grand doesn't feel the pull and no audible sound or noticeable diff ..
i have a z6 head and i hear and feel the change over
Old Jun 11, 2003 | 07:38 PM
Default Re: (cspciviclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cspciviclx &raquo;</TD></TR><TR><TD CLASS="quote">he has a 93 si with the z6 motor he says it hits a wall at 6 grand doesn't feel the pull and no audible sound or noticeable diff ..
i have a z6 head and i hear and feel the change over </TD></TR></TABLE>
exactly as he said, i think tomorrow im gonna hook an led up to the solenoid and see if it is kickin in and i jus cant hear it???
i checked everything possible, i know its only a z6 but i hear nothin and it feels like its hittin a brick wall around 5-6 grand, no cells, everything on cluster works, oil is fine, coolant is fine, what do i do&gt;
some more questions,
1. how does the ecu know that the motor is at the right temperature?
2. how does the ecu know that your going over 12 mph
3. does the gauge cluster have anything to do with the information being sent to the ecu, if so what wires do it and how&gt;?
Old Jun 11, 2003 | 07:39 PM
drunknbass's Avatar
unless you have a cel and your cel wire isnt hooked up right i dont see how your vtec woulnt work anymore.. its not like theres any wires going to the cluster that can control it either way
Old Jun 12, 2003 | 11:22 AM
anyone else have an idea???
Old Jun 12, 2003 | 07:00 PM
80884's Avatar
Default Re: (coptzer)
try running a power wire from the battery to the vtec solinoid to make sure the system is even working. Make sure you are reving the car a little at the time. I had a problem with my 00 si after i wrecked it an it turns out the ecu needed unpluged for a while and then it worked again. This was after I went over the entire system and ordered a new ecu. but now they both work. Just so you know I had no CEL when the vtec didn't work. Even when I engaged vtec at idle with my wire! Don't trust the cel. Run the wire like i said, if it works when givin power, unplug the ecu for a while and try it again, other than that????
O yea, one more thing, my rev limiter was droped 2,000rpm when this **** happened.
Old Jun 12, 2003 | 07:07 PM
my rev limiter is fine, i ran power wire to solenoid from battery, heard the clicking, next thing im goin to do is run wire from solenoid to a lil led and is it lights up when im supposed to be in vtec then i will be disappointed, if it doesnt i have no idea how to get vtec to engage,
i also unplugged ecu, unplugged battery , tried everything to perhaps reset the ecu.. i am soo stumped
Old Jun 12, 2003 | 08:48 PM
Dengar's Avatar
I can't hear it engage either on my SOHC, but the little light tells me that it is working.
Old Jun 13, 2003 | 06:30 PM
Default Re: (Dengar)
well i put in a new vtec oil pressure sender , and solenoid, and hooked up a test light and now it works, but totally disappoints me
Old Jun 13, 2003 | 08:16 PM
SICKSOLSI's Avatar
hard wire from the solenoid with a turnsignal bulb...did it tonight on my buddies 92 si actually he put a gsr cluster in too
Old Jun 13, 2003 | 09:49 PM
STIBungy's Avatar
Does the GSR cluster fit easily into a 5G?
Old Jun 14, 2003 | 01:50 PM
Default Re: (B18CBungy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">Does the GSR cluster fit easily into a 5G?</TD></TR></TABLE>
fits fairly easy untill you hafta put the bezel back in, fortunately i havent attempted to do that yet,
97D16Y7
Mar 18, 2025 07:34 PM
96civic808
24
Apr 22, 2010 04:42 PM
skiracer8148
18
Mar 10, 2008 03:19 PM
Honda-Hooligan
Oct 11, 2004 06:45 PM
cookci
21
Mar 31, 2004 05:35 PM
