car will not start, main relay the cause?
Old Jun 10, 2003 | 11:38 PM
sxecustoms's Avatar
Default car will not start, main relay the cause?
i have an 88 si w/d16a6 that will not start when its either hot outside or it hasnt been driven in awhile. after numerous trys it will usually crank after around 45 min or so. ive heard these car tend to have issues with their main relays after some time. any thoughts will be appreciated.
Thanks in advance
Old Jun 11, 2003 | 02:06 AM
iain's Avatar
do you hear the relay click when you turn the key to ignition position 2?
if not, then it's the main relay
Modified by iain at 1:27 PM 6/11/2003
Old Jun 11, 2003 | 03:01 AM
LowBuckRacin's Avatar
Well click this http://www.crxsi.com/resources...relay/ and it will help you repair your main relay by yourself. Hope this helps
Old Jun 11, 2003 | 03:13 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (LowBuckRacin)
another thing.. check the ignition switch..
its the 1st in the chain of command... if in the ON key possition, its not getting a good contact.. the car won't do ****.. the key comes 1st..
ignition switch
main relay
battery
starter..
Old Jun 11, 2003 | 09:18 AM
therealciviczc's Avatar
From the symptoms, I'd say there is a 90% chance of main relay. Like the above post, there are other options, but personally I'd check the relay first just based on the symptoms and the fact that they seem to go bad frequently.
Old Jun 11, 2003 | 07:47 PM
sxecustoms's Avatar
great, i think ill go ahead and replace it.. thanks guys
D7KWagon
Aug 28, 2014 12:20 PM
cwd14
Oct 7, 2006 01:06 PM
91d15bvtec
Jun 27, 2005 06:15 PM
speedymon
Dec 13, 2004 11:18 PM
DIY_Racing
Feb 23, 2003 10:48 PM
