Help with hesitation problems please
Old Jul 19, 2001 | 01:07 PM
GruvyTune's Avatar
New User
Default Help with hesitation problems please
I have a 95 GSR and it hesitates at low rpm. I just finished putting in a Skunk2 manifold, new fuel rail and new Type R injectors, B&M fuel regulator and gauge, new plugs, changed my timing belt and water pump, put in an undersize crank pulley and adjusted my valves. I have my timing gears at stock settings till I can Dyno tune.
I get the some kind of hesitation as I accelerate and get close to 3000 rpm. After that I get pretty smooth acceleration--even better than before.
Why the hesitation?? I have no clue. I don't find any vacuum leaks or anything. Don't burn a drop of oil and have never suspected a compression problem. Is it a fuel problem? Oxygen sensor perhaps?
Any help in what to look for would be appreciated.
thanks
tf
Old Jul 22, 2001 | 01:10 PM
Ricehornet's Avatar
Default Re: Help with hesitation problems please (GruvyTune)
i have the same problem once in a while, i suspect the weather for some reason....
also, someone said they experienced somthing similar to that, hesitation and what not, and then a surge of power....he was detonating
what do your plugs look like, maybe your a/f is off?
Old Jul 22, 2001 | 01:46 PM
GruvyTune's Avatar
New User
Default Re: Help with hesitation problems please (Ricehornet)
brand new NGKs gapped to spec (1.3mm).
I thought I had the problem licked the other day by lowering my fuel pressure. Its back again today. I'm still trying to figure it out.
torin
Old Jul 22, 2001 | 02:30 PM
raene's Avatar
There seems to be more and more people with this problem. I really wish I knew what the problem was!
Old Jul 22, 2001 | 02:37 PM
GruvyTune's Avatar
New User
Default Re: Help with hesitation problems please (raeneshadow)
similar stuff happened on my older Integra. I am baffled at this point.
Old Jul 24, 2001 | 08:42 PM
Ricehornet's Avatar
It happened to my car after Acura replaced my faulty injectors/dist./starter. did reseting the ECU help?
Old Jul 25, 2001 | 10:42 AM
Leo95SE's Avatar
my guesses are that
1. your running rich (GSR cams? you didnt say, sounds like a lot of fuel for stock cams)
or
2. valve lash set too tight. lopey idle and hesitation can sometimes be attributed to too tite a lash, i belive...
or maybe its just the weather.
HTH
forcefedcivic27
Jul 19, 2004 10:45 AM
GruvyTune
Jul 20, 2001 01:52 PM
95PRELUDEVTEC
Jul 17, 2001 06:43 PM
GruvyTune
Jul 11, 2001 06:40 AM
