my tegs making noises
From: Put it in..Take it out... Put it in..Take it out, United States
i have a 1990 LS all stock and when i go over 20 mph it starts squeeking... but then when i push in the clutch it stops... then we i let off it starts right back up until i go under 20mph again.... any ideas' on wut it could be????
more info..how many miles on your car? when's the last time you replaced the clutch?
it could be the throw-out bearings going bad...
no i know for sure its not the tires.... its comin from the engine... the clutch is only 700 miles old.... and the motor only had 2k on it....
halfshaft..drive axles..have you replaced the cv joints??...it could be something as simple as the speedo cable needing to be lubed...but that would make noise anytime the car was moving...
g2tegsown
Jul 19, 2007 08:58 AM
