help removing tar
Old Jun 10, 2003 | 09:25 PM
etmoron's Avatar
Default help removing tar
When you gut your car , right when you take out the door panels and theres the plastic film or whatever , peel that and it leaves like sticky tarlike glue . any suggestions on how to remove it , or anyone know how to remove it ? i used goo gone but not that effective .
Old Jun 10, 2003 | 10:34 PM
etmoron's Avatar
Default Re: help removing tar (etmoron)
Old Jun 10, 2003 | 11:10 PM
im_poor's Avatar
i would also like to know.
Old Jun 10, 2003 | 11:17 PM
SikofFalln's Avatar
Default Re: help removing tar (im_poor)
Could you freeze it with dry ice and then chip it off? That is how I removed the tar from my floor boards.
Old Jun 11, 2003 | 01:22 AM
EKFerioHawaii's Avatar
Default Re: help removing tar (BseriesPWR)
- Heat it up with a low temp heat gun.
- Scrape away with a stiff metal spatula
- If you still can't get it off, use a wire brush bit on a good drill
Someone also told me to use Castrol Super Clean and a little bit of
the original Goo Gone or Goof Off (as seen on tv).
Old Jun 11, 2003 | 02:05 AM
ThisLittleSleepeR's Avatar
Default Re: help removing tar (EKFerioHawaii)
when its hot , its easy to play with, just start peeling
Old Jun 11, 2003 | 02:20 AM
4DeepCivic's Avatar
Default Re: help removing tar (ThisLittleSleepeR)
I've done the heating method.. it sucks!! Use the dry ice method.. cleaner and easier....
Old Jun 11, 2003 | 02:37 AM
etmoron's Avatar
Default Re: help removing tar (4DeepCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DeepCivic &raquo;</TD></TR><TR><TD CLASS="quote">I've done the heating method.. it sucks!! Use the dry ice method.. cleaner and easier.... </TD></TR></TABLE>
you done it and it accually worked ? of yes how long it took you ?
Old Jun 11, 2003 | 04:19 AM
ntrinsik's Avatar
Wouldn't liquid nitrogen work best for freezing it?
Old Jun 11, 2003 | 09:21 AM
95hbMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThisLittleSleepeR &raquo;</TD></TR><TR><TD CLASS="quote">when its hot , its easy to play with, just start peeling</TD></TR></TABLE>
That's what she told me!
Old Jun 11, 2003 | 12:17 PM
bdb's Avatar
bdb
Default Re: help removing tar (95hbMatt)
If your talking about the more flexable black tar used to glue the window flims on the doors just use something like 3M adhesive remover or Goof Off! The hard tar in the floor pans requires dry ice and a lot of elbow grease (there is a wicked how-to on the board) and if you mean the tan colored putty a heat gun and putty knife will get that off.
Old Jun 11, 2003 | 04:11 PM
LSpimpTEC's Avatar
i just read a thread a couple days ago with it. the guy walks you through it. he uses dry ice. search it.
Old Jun 11, 2003 | 04:20 PM
VX's Avatar
VX
Default Re: help removing tar (LSpimpTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSpimpTEC &raquo;</TD></TR><TR><TD CLASS="quote">i just read a thread a couple days ago with it. the guy walks you through it. he uses dry ice. search it.</TD></TR></TABLE>
Yep, but this is for the floorboards ( https://honda-tech.com/zerothread?id=525936 ) for the doors just use a heat gun and peel.
Old Jun 11, 2003 | 04:49 PM
tek_civic's Avatar
Default Re: help removing tar (VX)
damn, i must have been really lucky with my floorboard tar, all i did was get an edge of my screwdriver under it and levered it up, i got both driver and passenger sides up in almost one piece. the rear section was a little harder, so what i did was dig a corner of the tar up with the driver and jammed it in and broke it up, got that tar off in about an hour. but in total i only saved about 20 lbs. o well
Old Jun 11, 2003 | 04:57 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: help removing tar (tek_civic)
just use some goof off or paint thinner.
If you use a scraper or wire wheel, you'll scrap your finish to pieces
Old Jun 11, 2003 | 05:00 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, but this is for the floorboards ( https://honda-tech.com/zerothread?id=525936 ) for the doors just use a heat gun and peel.</TD></TR></TABLE>
I was just about to refer to this bad *** thread that VX made
577HondaPrelude
19
Apr 1, 2006 06:45 PM
EMJAY
Mar 4, 2006 03:50 PM
cilvia
26
Feb 7, 2006 06:48 PM
ekdriven
Mar 8, 2005 08:00 AM
95civiccoupe31
13
May 29, 2002 06:38 AM
